starts then dies when switch is released
Old Jan 24, 2010 | 08:27 PM
1994z's Avatar
Default starts then dies when switch is released
starts then dies when switch is released. maybe one of the pink wires doesnt have power when key is released?
Old Jan 24, 2010 | 08:39 PM
Smo's04Gto's Avatar
Vats?Mine will start and then die,if the vats box is not turned on.
Old Jan 24, 2010 | 09:14 PM
Pocket's Avatar
Sounds like you're pulling IGN power from the starter solenoid wire
Old Jan 24, 2010 | 09:34 PM
1994z's Avatar
got the box in the car to disable vats.
Old Jan 24, 2010 | 09:37 PM
1994z's Avatar
will look into that tomorrow
Old Jan 24, 2010 | 10:58 PM
bczee's Avatar
Make sure you have the correct power to the required PCM terminal.. you need direct 12+v to the PCM and also IGN 12+ in the run only. Check you wiring diagram for the correct type of power.
Not sure how the early 4th gens are wire at the start, but yes.. if you get power from the starter solenoid's smaller term's.. it will cut off power as you release the key from start to run.
Old Jan 25, 2010 | 12:45 AM
the_merv's Avatar
Veteran: Air Force
Yea sounds like one of the Pink Wires isn't in the correct spot..
Old Jan 25, 2010 | 04:34 AM
Pavetim's Avatar
Does it almost start then die, or run for like one second then die? Getting a security light on dash?
Old Jan 25, 2010 | 04:46 AM
the_merv's Avatar
Veteran: Air Force
From what I get by what he said it starts when the Key is in the start position, but when you let it come back to the run position it dies.
Old Jan 25, 2010 | 07:38 PM
1994z's Avatar
correct what merv said. does any of the wires from the two plugs on the wheel well need to be attached anywhere if the harness is a standalone system.
Old Jan 25, 2010 | 11:53 PM
the_merv's Avatar
Veteran: Air Force
Well from what it sounds like the main Ignition Wire(s) is(are) connected to the one with the Starter..there should be only one wire coming out of the Ign Switch to the Starter, like 2 or 3 on the spot where the Key is in Run.
That or the switch is like really fubar..lol
What car is this?
Old Jan 26, 2010 | 09:10 PM
1994z's Avatar
its the 96 firebird that i am doing the swap in. had a v-6 in it.
Old Jan 26, 2010 | 09:40 PM
Wesmanw02's Avatar
I repaired an early 90's Honda Accord that exhibited this exact symptom.
I diagnosed it as a bad ignition switch, which was the problem.
Old Jan 27, 2010 | 07:14 PM
1994z's Avatar
alright here is another one. checked fuel pressure good. checked each injector pulse and sprays a good stream of fuel, with a kent moore injector testor. if i bump the starter over a couple of times with out trying to start the engine, it will fire and run for about 4 seconds. then die, got it to run about 3 times like this before i quite for the evening. what should i look for?
Old Jan 27, 2010 | 08:09 PM
thirdgengta350's Avatar
Hmmm. the symptoms definately point to bad fuel pump or clogged filter. but you say you have good pressure. what kind of pressure readings are you getting? all in all i'd probably have to say +1 on ignition switch
Old Jan 27, 2010 | 08:20 PM
1994z's Avatar
new pump and corvette filter/reg. 55-60 psi on the gauge
Old Jan 27, 2010 | 08:45 PM
did you mess with the timing or anything to do with it lately?
Old Jan 27, 2010 | 08:52 PM
1994z's Avatar
no. this is a new build.
Old Jan 27, 2010 | 10:13 PM
it's mind boggling to say the least. i'd just go through to check and re check all your wiring.
Old Jan 27, 2010 | 10:19 PM
Wesmanw02's Avatar
Was the VATS light on while you were doing this??
