Block-off plate for automatic trans. bellhousing?
Old Jan 30, 2010 | 07:00 AM
goatcrazy's Avatar
Default Block-off plate for automatic trans. bellhousing?
Question: I've got an LQ9 truck motor and a truck 4L60E transmission that I'm in the process of mating together. On the LQ9 motor, I'm also using an Autokraft oil pan. There are open "spaces" between the engine and the bellhousing on both the driver's and passenger's side (as well as the bottom with the Autokraft oil pan) of the bellhousing. What have you guys used to cover that up? Is there a factory part that could I could order?
Any advice would be appreciated!
Thanks!
Old Jan 30, 2010 | 08:27 AM
Professor_speed's Avatar
you might try an inspection plate from a pre gen III engine trans combo. (sbc)
Old Jan 30, 2010 | 08:55 AM
Pop N Wood's Avatar
Maybe these will work
Old Jan 30, 2010 | 09:10 AM
Pocket's Avatar
Use a piece of tin
You may luck out and only have to redrill the mount holes for a T5 or older clutch plate but its such a simple piece, just cut your own
Old auto dust covers will not work
Old Jan 30, 2010 | 09:02 PM
goatcrazy's Avatar
Is that one per side? IS there any way that you could snap a quick pic showing each bracket (a little hard to tell where these bolt up)
Thanks for your help!
Old Jan 31, 2010 | 08:54 AM
Pop N Wood's Avatar
Actually I don't have those, yet. Another member forwarded me those pics when I mentioned I needed something similar. I am pretty sure they are left and right side.
GM direct sells them for about $4 each, but with $15 S&H (bastards). So for less than $25 they are probably worth a try.
Old Jan 31, 2010 | 09:19 AM
garys 68's Avatar
I bought those parts for an 02 camaro at the dealer, about $15.
They filled in the space on either side of my LQ9 6.0 mated to a BBC bell housing/ROD trans. I used a vette batwing oil pan that fit flush with the bell housing bottom, so I didn't need an extra piecs to fill between the 2 side pieces listed.
