Vss
Old Jan 30, 2010 | 01:29 PM
dimetweaker's Avatar
Default Vss
I started to get some info on this in another thread I started, but I wanted to ask this here to get some input from all the swappers;
Do I have to run a VSS on my swap set up in order to get the computer to function correctly? I have been researching these swaps forever on another forum before I jumped on here and never ran across anything about a VSS until I was on here so I wanted to get some insight... Motor is basically an LS3 with a TH350 going behind it. Thanks in advance!
Old Jan 30, 2010 | 01:51 PM
jomomma's Avatar
me too, me too! im running a 5.3/ th350. ive been told that without one, the motor will want to die when coming to a stop after driving. i would definetly like to find out for sure what we need.
Old Jan 30, 2010 | 02:25 PM
busta9876's Avatar
I used Dakota Digital SEN-4160 on my TH400 behind my 5.3L vortec. Sensor is about $35.00 This sensor creates about 8000 pulse/mile. PCM will need programmed to read the lower number of pulses this sensor produces, but it does work. This fixed the idle issue when coming to a stop. This also allows the PCM to use a wider range of fuel trim cells. Over all better running engine.
Old Jan 30, 2010 | 02:54 PM
ok then!
Old Jan 30, 2010 | 02:58 PM
so does it screw into the gear for the speedo output cable or what?
Old Jan 30, 2010 | 10:33 PM
jomomma's Avatar
where can you get this sensor?
Old Jan 31, 2010 | 08:40 AM
poconojoe's Avatar
http://www.summitracing.com/parts/DAK-SEN-01-4160/
Old Jan 31, 2010 | 08:42 AM
busta9876's Avatar
http://www.dakotadigital.com/index.c...rod/prd109.htm
Part# SEN-4160 has cable pass-through that allows you to still run a cable speedometer.
Part# SEN-01-1 goes on GM cable output of trans, NO pass-through for cable speedometer.
Old Jan 31, 2010 | 12:13 PM
jomomma's Avatar
i just ordered mine!
