Wiring question..
Old Feb 5, 2010 | 11:52 AM
the_merv's Avatar
Veteran: Air Force
Default Wiring question..
There is a wire in the LS1 Harness that goes to the PCM called the Theft Deterrent Fuel Enable.
Going on a hunch here..that is the one signal wire that the Key Chip tells the PCM it's the correct one and it enables the Injectors.
Now if the VATS is disabled, can that wire be removed without and issue..?
Just a thought, if I was home I would un-pin it and see for myself.
Old Feb 5, 2010 | 04:12 PM
Pocket's Avatar
You are correct and it can be removed
Old Feb 6, 2010 | 05:07 AM
the_merv's Avatar
Veteran: Air Force
That's what I thought..cool.
Old Feb 6, 2010 | 08:59 AM
InsaneAuto86's Avatar
Good to know. I'm working on the harness now...
