Good crate motor price????
Being FARRR from an expert on the LS motors, I was wondering if this is a decent deal for the package. http://www.ultrastreet.net/engines/427_ls3.asp
I am building a 65 GTO and have watched B-Man and other's threads regarding A-Body installs. My main questions are (1) is this decent package for the price and (2) would it be possible and worth the expense to look at a Magnacharger for this motor a few years from now??
If this isn't that good of a deal or the company is questionable, do you have any direction I should go????
Any input/advice is greatly appreciated.
I have heard good things about Mast from a few people. My concern was that there are sooo many combos out there that it is a little difficult to price compare at times and this package seems to include most of the required equipment, however either way it is alot of $$$$$
Probably about $8-9k for something like an LS3 delivered. Or around $14.5 - 15k for an LS7 with controller kit.
MAST does add in considerable value over a GMPP LS3 and its really about whether that is worth 4-5k additional value for the user's application/objectives.
Certainly one space where MAST will be in front is that their controller supports GM electronic autos whereas the GMPP engine controller does not.
Given it is a forged 4.1" stroker and is hand built with good parts vs production line assembled, run in on a dyno and does 610HP, sure sounds like reasonable value if you are after a 427 with 610HP ready to roll.
11:1 compression ratio is pretty high for a blower. You might give them a call and tell them you want to go forced induction. Since they offer a selection of accessories and oil pans they might be able to subsitute some lower compression pistons.
