carbd LQ4
Old Feb 7, 2010 | 08:43 PM
sowaidi's Avatar
Default carbd LQ4
im swapping out a 04 LQ4 that was boosted for 15K. Im going with L92 heads. im replacing all the gaskets and seals of the top end of the motor. should i upgrade any other parts like the rod bolts?
LQ4/L92 Heads/Hot cam kit
Old Feb 7, 2010 | 09:22 PM
NemeSS's Avatar
mill the heads, ls2 head gaskets. rod bolts only neccessary if plan on constant 65-7000rpm or heavy racing. if street car, not needed.
Old Feb 7, 2010 | 09:42 PM
nastychevelle's Avatar
dont do a hot cam have one custom spec'd for you
Old Feb 8, 2010 | 12:58 PM
sowaidi's Avatar
ill contact comp cams and have one done instead.
im planning to use stock L92 heads, would i have to mill them anyway?
thanks
Old Feb 8, 2010 | 01:06 PM
tennerv8's Avatar
This is the build im doing. Should be 550hp at the crank with the cam and heads they used. Just L92's and a camp swap.
http://www.carcraft.com/techarticles...ads/index.html
Old Feb 8, 2010 | 02:56 PM
thanks
get in contact with pred z or pat g they will hook you up
Old Feb 8, 2010 | 03:06 PM
NemeSS's Avatar
if u dont mill them it will around or just under 10:1 scr.
Old Feb 8, 2010 | 04:15 PM
LS GT's Avatar
that build sounds INCREDIBLE!! and incredibly easy! so if that thing makes 550hp roughly at the motor, is it safe to assume that you'd end up with 468hp at the rear wheels? i'm amazed at how much power these motors will make with factory parts! i'm sold.
Old Feb 8, 2010 | 04:33 PM
NemeSS's Avatar
roughly about 440rw thru built drivetrain, trans, stall, and reinforced drag type rear end.
with manual car and basic or upgraded rear around 460-465rw
Old Feb 8, 2010 | 11:18 PM
1970camaroRS's Avatar
Rod bolts are a cheap $70 insurance policy. I'd put them in any motor you have on an engine stand.
Old Feb 9, 2010 | 07:22 AM
jasonsnova's Avatar
i'm doing the same thing....i'm gathering parts now,and was thinking about that build too but just a bit worried about low end driveability...a few people on here said it wouldnt have good driveability. i wanna here from all those cam guru's out there!!!
Old Feb 9, 2010 | 09:31 AM
LS GT's Avatar
sure beats stroking a 351, having to get the block machined, and HOPEFULLY ending up even close to those numbers!!!!
Old Feb 9, 2010 | 12:19 PM
sowaidi's Avatar
i dont know what id expect. its going in a 83 3/4 2dr truck, factory SM465 and 14 bolt. i want to get over 400rwhp but im not sure if i can get there.
Old Feb 9, 2010 | 12:58 PM
tspence45's Avatar
Damn. If I wasn't so worried about losing low end torque, I'd try to pick up a set of L92 heads. Those hp numbers are awesome.
Old Feb 10, 2010 | 05:49 PM
NemeSS's Avatar
while this is true, not many people own a rod bolt stretch guide. and i for one will not install rod bolts in any motor without the correct values or without use of this tool.
they are not entirely neccessary if not plan on racing or hi rpm. in a street motor.
Old Feb 10, 2010 | 05:56 PM
tennerv8's Avatar
If you get arp bolts they have instructions for installing them with a torque wrench. I just recently did this on my 6.0.
