blue/green harness to blue green pcm?
I just received a truck harness that the seller said came from a van that had Drive by cable, '04 I think, and it has blue/green pcm connectors.
Do I need to use a '04 pcm? Does it matter if it comes from a 5.3 or 6.0? I can pick them up from local yards for $45 for 5.3 and $60 for 6.0. Or can I get an earlier pcm? I assume that would be just more work, right?
LOTS of questions to come, as I want to give myself a chance to rework the wiring harness with help from this forum, and lt1swap.com.
thanks
thanks
If you used an earlier pcm say a red blue connector one you'd have to modify the harness cause the pinouts are different. You can use a 5.3 or 4.8 pcm as long as it's drive by cable but you'd have to have it flashed for your tune.
