72 chevelle getting the ls2 with t56
Old May 12, 2010 | 02:21 PM
lizeec's Avatar
Default New Line
I ran into the exact problem you have, I tried to look for a company that maybe made an adaptor hose that would have the FBody master cylinder fitting on one side and the GTO Slave cylinder fitting on the other side and I did find a company called tube-tech that knew of my exact problem and were in the prototype stages of having something to offer for this problem but they told me that it was still about 6 months from production but now that was about 18 months ago that I had that problem so they or somebody may have come up with an adaptor hose by now? Another solution is that the slave cylinders from the FBody and the GTO are identical except for that one fitting if you know of a transmission shop or friend that has done a clutch on his FBody and changed out the slave cylinder and has the old one laying around you can just swap the fitting instead of having to buy a whole new FBody slave cylinder which usually run from as cheap as $65 up to about a $150 and from what I have seen they are all the same brand. Good Luck
Old May 12, 2010 | 04:19 PM
Tony C.'s Avatar
OK Thanks
Old May 12, 2010 | 06:16 PM
PUD'S BOY's Avatar
What Alternator and AC mounts are those. Look really clean , durable. My 1971 Chevelle LS2 T56 swap starts next month. Got a garage full of parts. Im interested in your progress and your car is very nice. Like the paint. Itll be one bad boy when its finished. Good luck!
Old May 12, 2010 | 07:03 PM
Tony C.'s Avatar
Thanks. The brackets are from kwik performance and its a very nice peice,durable and easy to install. If you have any questions with your install just let me know and i'll try to help.
Old May 13, 2010 | 11:27 PM
clm69z28's Avatar
I installed the Spectra tank in my 72 Chevelle with the in tank pump and hooked up the vent tubes just like the factory tank. You should have the same amount of vent tubes that are on the tank.
On another note, you might want to consider a pan that does not hang below the x member. The Autokraft pan fit real well with my Edelbrock set up.
Attached Thumbnails 72 chevelle getting the ls2 with t56-p1010323.jpg   72 chevelle getting the ls2 with t56-p1010322.jpg
Old May 14, 2010 | 05:25 AM
Tony C.'s Avatar
I have the same fi spectra tank, i don't have all the lines someone removed the canister filter. I'm gonna try it out with two caped off and one vent.
Old May 23, 2010 | 11:10 PM
Tony C.'s Avatar
I received my breaks on friday and installed them yesterday and today. Everything worked out pretty good.I need some help with gears and positive unit, where is the best place to get them? I'm looking for 373's. Here's a few pics of my breaks.
Attached Thumbnails 72 chevelle getting the ls2 with t56-hjgyt90po78p-083.jpg   72 chevelle getting the ls2 with t56-hjgyt90po78p-085.jpg   72 chevelle getting the ls2 with t56-hjgyt90po78p-088.jpg   72 chevelle getting the ls2 with t56-hjgyt90po78p-090.jpg   72 chevelle getting the ls2 with t56-hjgyt90po78p-098.jpg
Old Jun 15, 2010 | 02:45 AM
tiger70h's Avatar
Default regarding your cluthch set up ............
were did you get all the parts to make your clutch pedal work ? iam doing the same conversion... and right know my car is a automatic but iam going to put the t-56 in but iam lost on where to get the parts .... could u help me thanks
Old Jun 15, 2010 | 04:07 AM
Mike Broadway's Avatar
Good looking ride I like it !!
Old Jun 20, 2010 | 11:48 AM
Tony C.'s Avatar
My car was a 4speed from the begaining so i used my old pedal, you can find parts like on ebay and switch it over to manual
Old Jun 27, 2010 | 01:56 AM
tiger70h's Avatar
ok cool... so what did you end up using for the slave cylinder and everything else that had to do with that problem i need some help there
Old Jun 28, 2010 | 10:57 AM
  #32
Tony C.'s Avatar
You will need to get a master cylinder adapter bracket and master cylinder for an 02 camaro or firebird, i got mine off ebay from nook & tranny,there web is www.nookandtranny.com
Old Jun 29, 2010 | 09:33 AM
  #33
Tony C.'s Avatar
IT'S ALIVE!!!!! IT'S ALIVE!!!! I got my fuel line in on friday installed it sunday primed it and she started on the first try. Damn! music to my ears.
Old Jul 7, 2010 | 12:08 AM
  #34
Tony C.'s Avatar
I have the engine running and can't wait to take a drive up the street.I'm now working on the clutch bracket and gas pedel. I'll post new picks tomorrow.
Old Jul 8, 2010 | 12:42 AM
  #35
Tony C.'s Avatar
new pics, almost complete
Attached Thumbnails 72 chevelle getting the ls2 with t56-hjgyt90po78plp6co-022.jpg   72 chevelle getting the ls2 with t56-hjgyt90po78plp6co-023.jpg   72 chevelle getting the ls2 with t56-hjgyt90po78plp6co-025.jpg   72 chevelle getting the ls2 with t56-hjgyt90po78plp6co-066.jpg   72 chevelle getting the ls2 with t56-hjgyt90po78plp6co-068.jpg
Old Jul 10, 2010 | 02:42 AM
  #36
tiger70h's Avatar
Default can you tell me what i need thanks
ok thanks i check out the site.... but i have this all ready conected to my tranny what do you think ill need can you help me out???? here are some pics..iam happy u got your car running congrats!!
Old Jul 14, 2010 | 12:12 AM
  #37
Tony C.'s Avatar
Hey,sorry for the delay. Thats a newer t56 trans,you need to get a slave cylinder,master cylinder and bracket for a 2002 t56.What you have in the pics will not work,you need to change the slave cylinder to the 2002 style.
Old Jul 20, 2010 | 01:25 AM
  #38
tiger70h's Avatar
ok thanks i was con fused on what i needed. i have another questions how did you connect you steering ?
Old Jul 22, 2010 | 12:30 AM
  #39
Tony C.'s Avatar
I used braided lines, fittings and aftermarket
Old Jul 29, 2010 | 12:35 PM
  #40
chuckd71's Avatar
Did you have any issues with your spectra tank install? Cut the trunk out or anything like that?
