My 92 LSx Swap...
Old Mar 11, 2010 | 07:02 AM
BlackTA96's Avatar
Its alive!!!
Old Mar 14, 2010 | 08:22 PM
seawalkersee's Avatar
Just make sure you take care of the leaky brakes on the rear of that thing. I would hate to have to have you sell it to me for a mere $50 dollars after you wrecked it because you had no brakes.
SWS
Old Mar 14, 2010 | 11:15 PM
98ws6&02gtp40th's Avatar
dude that is so badass... best way to make a ford fast.. but a ls in it.. lol
Old Mar 15, 2010 | 01:31 PM
Here we go again....
SWS
Old Mar 15, 2010 | 05:23 PM
BlackTA96's Avatar
Oh yea! The leaks been fixed. The rear end has c-clip eliminators, so it was actually gear lube that was leaking. But its taken care of already.
I got the motor/trans in the car, and wired everything up. Got the fuel lines ran as well. But i'm having issues with the dynatech headers and the steering shaft.
Old Mar 15, 2010 | 06:25 PM
Jimbo1367's Avatar
Damn dude. You got a great deal from what it looks like. Keep up the good work
Old Mar 15, 2010 | 08:11 PM
BlackTA96's Avatar
Thanks man!
But now i've run into an issue with the headers hitting the steering column. Trying to get it sorted out.
Old Mar 16, 2010 | 04:23 AM
hybridstang's Avatar
Look great and great cam choice thats what i got originally but decided to go with the vortech so i can't use the ms4
Old Mar 22, 2010 | 08:51 PM
BlackTA96's Avatar
Started her up in the car tonight, got all the wires ran and it fires up perfect everytime.
Man!! I can't wait to get this thing on the streets!!!
Old Mar 22, 2010 | 09:35 PM
BlackTA96's Avatar
Old Mar 22, 2010 | 10:02 PM
dmracing's Avatar
Looks great, did you get anything figured out with the headers?
Old Mar 23, 2010 | 07:03 AM
  #32
BlackTA96's Avatar
Yea, check out my thread.
https://ls1tech.com/forums/conversio...come-here.html
Old May 1, 2010 | 07:26 PM
  #33
BlackTA96's Avatar
Well, just a little update. Not much has changed. I'm waiting on my revised header to get back from the ceramic coaters and i'll get that back on.
Things have been really slow at work lately so they've been cutting hours, so no extra dinero right now. but hopefully things will get back on track and i can this thing on the raods soon
Old May 2, 2010 | 09:45 AM
  #34
LS88FoxBody's Avatar
Where did you get that throttle cable? And did you run your ingition power off the starter solenoid like ford originally did?
Old May 3, 2010 | 08:33 PM
  #35
BlackTA96's Avatar
Throttle cable is made by Lokar. Jegs and summit has them.
No, I ditched the ford solenoid. I just spliced into a wire under the dash that came on with the key in the "start" position. Ran that wire to the solenoid on the LS1 starter. Works like a charm.
Old Jul 6, 2011 | 01:09 PM
  #36
BlackTA96's Avatar
OVER A YEAR LATER!!!
She's still not on the road,
But its awful close!
Only thing I have left is to finish up the radiator/fans, bolt up the torque converter, and buy gauges!!
Trying to scrouge(sp?) up $700 for gauges is my next hurdle.
Old Nov 28, 2011 | 09:52 PM
  #37
lsvpeter's Avatar
looks good man!! keep us updated on your progress!!! LIKE THEY SAY, "SLOWLY, BUT SURELY!!" keep it up!!!
Old Dec 1, 2011 | 11:01 AM
  #38
BlackTA96's Avatar
I've order the gauges and am in the process of wiring them up. Man, its a huge pain in the ***!!
Fans are wired, Torque converter bolted up!! Getting closer.
I also order a set of Hooker Aero Chambers. Next will be exhaust!
I also just ordered everything to hook up my power-steering.
Here's a part list if anyone's interested:
135-RP1300 - This is a flow control valve, it knocks down the pressure from the GM pump to what the ford steering rack needs.
You will need a 16mX1.5 and a 14mmX1.5 fitting for the ford power-steering rack.
Then of coarse AN fittings and Hose approved for power-steering use.
Cost me about $120 shipped for everything.
Once the power steering is hooked up, and the gauges wired...fingers crossed....I should be able to take it on a test drive!
Old Dec 3, 2011 | 08:40 AM
  #39
BlackTA96's Avatar
Here's all the goodies for the power-steering!
You have to remove this from the pump (7/8")
Here's a picture of the old and new fittings
The new fitting installed
This is the first time I've ever made hoses with the plastic in the center...
Well long story short.. I messed up the thread on one of the fittings. Have to wait till next week and order a new one.
Old Sep 8, 2012 | 07:01 PM
  #40
N20neenee's Avatar
Any updates on this bad boy?
