LS power into 1980 Firebird
I just ordered some stuff for it from Summitt Racing though, got an adjustable proportioning valve, a billet steel pitman arm for the steering box, and a 10 psi residual pressure valve to reduce pressure for the rear drum brakes when I get a disk/disc master cylinder along with more
polyurethane bushings for the damm lower arms of my 4th gen and a tranny mount.I'm hoping today I can sand down the firewall again to paint it black, that gray por-15 turned yellowish.
Took water pump off, valvecovers, and intake to remove all the oil/dirt that was built up on it and now it looks alot cleaner. Rich
Now I'm stuck between going with an LS/T56 swap but I'm a little concerned about how long that would take and making all the wiring and gauges work properly, but this would be a sick ride! My second option is to get 400/th400 (found one on CL for $500 but the guy hasn't got back with me)combo until I can come up with the funds for an LS motor then reselling the 400/th400 combo.
Anyways I would like to get some info on what it would take to do the LS swap so I can calculate cost. I have read about some edelbrock mounting plates that go pnto the the old mounts (from what I understood), but it was done on a 1st gen camaro, are they the same as 2nd gen T/A's and firebirds? If I do go this route I would have to sell my DD for funds, or trade for LS/t56 combo, which I'm trying to sell either way to get going with this project.
All opinions and advice are welcome wether it be for old-school carbed or LS swap.
PM me with any questions.
By the way the car is for sale. $19,000
