90 GT carb'd 6.0
Old 02-22-2010, 10:56 AM
imajeenyas's Avatar
Default 90 GT carb'd 6.0
My build is not nearly as pretty or insane as some, as a matter of fact it's a pretty straightforward swap into a mustang. I'm not a photographer or journalist either! All my pics were taken with my phone.
When i bought the car it was set up as a drag car. It already some nice work done on the chassis by Dial's race shop in Seminole, OK. Since i'm going to drive it as much as possible, i thought i would swap the power steering and brakes back into it. I am using the 94-95 brake booster, master cyl and prop valve, and steering rack. I used North Racecars disc brackets on the 8.8 rear.
AJE swap k-member, tubular a-arms, coil overs.
Lq4 stock bottom end.
F-body pan
Milled 317 heads, with just a port cleanup
Comp Cams 238/240 .605/.609 112
AFR springs
Victor JR intake
Quick Fuel carb
Dynatech headers
MSD to fire the coils
I was given a 700r4 to build so i guess that will be the first transmission.
I only have a few pics so far. The engine is just mocked up for it's photoshoot. Stil a lot to do.
Unloaded the project
Thought this was a nice touch.
Out with the old
In with the new
Makin' those $$$ for the swap...lol
Old 02-22-2010, 04:05 PM
99MUSTANG5.3L's Avatar
Nice lookin car. What kind of numbers are you expecting from that motor?
Quick Reply: 90 GT carb'd 6.0
