Help with ls1 gauges in foxbody
i used the 99 camaro gauges in my foxbody and then only ones i have got to work is the oil pressure, and the voltage........
i know the fuel pressure gauge will not work im not worried about that at all..... but water temp, speedometer, tach ,and odometer do not work
any ideas what is wrong here??? I have went back through the wires going to the gauges twice now and all the power wires have power.... all the grounds check good
and i have HP tuners to tune the car and when i hook up the computer to it......... it shows all the gauges working in the vcm scanner water temp, speedometer, tach, all work.........
one last thing..... every once in a while when i go to turn the car off or start the car.......... the backlight for the odometer that is red will flash for a quick second and go right back off..... the mileage never shows tho.......
all help is a big thanks
Just go back and check your wiring diagram again. You will get it.
there are 2 blue wires on this connector that have been cut.........
1 is a light blue and 1 is a dark blue
do you know what these go to? maybe this is part of my problem
