chevelle just cracked another tranmission case...
#42
Most car, as far as I know, off-set the motor to the right to help keep the u-joints from binding which may cause your cracked trans case issues. Because this it a swap and the vehicle has been hit in the front you may want to verify that the driveshaft is not directly inline with the rearend housing. There is a certain amount of degrees that the shaft has to be from side-to-side along with up and down.
Andrew
#43
when you break the tailshaft housing is the trans junk, or do you repair it?
Are broken trans worth anything - I have one, and was wondering whether to toss it or ...
