lsx-foxbody driveshaft length questions
I have been reading if you use a th350 with a 9" tailshaft you can reuse the stock mustang driveshaft.
Is this correct?
Is this with the 4.6 K member or the AJE kit? Or both?
I am also under the inpression the 4l60e and 80e are the same length as the above mentioned th350?
I have been searching and searching but noone clarifies what K member and mounts they have used.
Thanks, Steve
Is this correct?
Thanks, Steve
Steve, hopefully these will help you.
Proper way to measure driveshaft.
Transmission Dimensions
Mike
Mike
Thank you, now I need to know what K member setup to use with a th350 setup.
It says the 80e is roughly 2 inches longer than a 60e and th350 with the 9inch tailshaft.
