Grinding noise when accelerating hard!?!?
Old Feb 27, 2010 | 10:02 PM
chevrev's Avatar
Default Grinding noise when accelerating hard!?!?
Just got my LS1/4l60e into my 57. Runs great, smooth, powerful ,etc...BUT, when I really get on it and accelerate hard, there is an aweful grinding noise. It sounds like its under my feet (tranny area). My first suspicion would be the transmission. It was a fresh rebuild, but maybe not a good one??
Otherwise, it seems to shift fine and run out well, but that grinding noise has me worried!
Any ideas????
Old Feb 28, 2010 | 07:07 AM
55chevy's Avatar
I would look around the driveshaft and other areas to see if you have any clearance issues when the engine is under torque. Also, if you can see the flexplate, look for rubbing or loose bolts on it that could be rubbing.
Old Feb 28, 2010 | 07:25 AM
BadVRod's Avatar
Might check your rear end. Mine made a nice grinding noise right before it locked up.
Old Feb 28, 2010 | 07:38 AM
55chevy's Avatar
I was just thinking about the rearend and driveshaft length when I read this other post.. https://ls1tech.com/forums/conversio...sion-case.html .
Old Feb 28, 2010 | 07:53 AM
Jimbo1367's Avatar
Default noise
good idea.
Old Feb 28, 2010 | 11:15 AM
chevrev's Avatar
I jacked the rear end up and noticed that the floor pan tunnel just above the universal joint where the drive shaft meets the c4 differential has some gouging/scraping in it. The drive shaft/rear end joint must be flexing enough to touch it when put under a heavier load (ie, hard acceleration) to touch it. Hopefully this is the problem and the tranny is fine! We'll see...I'll make some adjustments/modifications so the universal joint can't make contact with the undercarriage and see if that solves it.
Old Feb 28, 2010 | 11:31 AM
gofastwclass's Avatar
Sounds like the car must be lowered. I've had that problem when the pinion angle was screwy or the car was lowered too much for the available transmission tunnel clearance.
Old Feb 28, 2010 | 02:49 PM
55chevy's Avatar
I'm not familiar with the c4 diff but I would think that there is some type of torque arm or stabilizer that helps to hold the pinion down during high torque. I still have my leaf springs but I have Caltracs that prevents the rotation of the axle during takeoff. It sounds like you are on the right track, good luck.
Old May 24, 2011 | 10:32 AM
chevrev's Avatar
Default No more grinding!
Just wanted to post an update on this issue. Redesigned the rear diff mount to give it more stability.
No more grinding noise when I accelerate!
Old Mar 24, 2015 | 07:14 PM
rtsland1's Avatar
Default no more grinding?
what was the remedy? having same issue w lowered ss
