6l60e or 4l60e out... question...
I've seen two 4L60E and one 4L80E wiring diagram along with a conversion diagram between the two but the pin-outs and colors I found were different than what I have in my harness???!!! I left the factory connector alone and installed it as it was. The only reason I even looked was I wanted to double check something before I installed it. Even more confusing is my transmission has worked fine the whole time (thousands of miles).
In addition, you should flush your transmission cooler and lines.
(The '07 Tahoe came with the 4L60E transmission behind a 5.3 engine, however, a 4.8 was also available)
