AC wiring?
I have the 2003+ truck PCM in my conversion, and I'm researching wiring for the AC. I'm hoping someone has had some experience with this issue since the posting in 2007
The old post concludes that the only way to run the AC using the PCM is to scab on a HVAC Control Module because it says the signal to the PCM to turn on the compressor is a Class 2 data signal.
But when I look at the diagram attached, it looks like the AC compressor signal is just 12V out of the HVAC module going through a low pressure switch
It looks like to me that the 12V AC demand wire from the donor car could be hooked to the compressor clutch via the low pressure switch and the PCM would control the compressor by switching the ground on and off.
Is the class 2 data signal there to turn the compressor on and off or just for data/diagnostics?
Anybody done this?
Phil
Anybody done this?
Phil
Now for the interesting part, I'm going to assume you're keeping the DBW, or else you could get a PCM from a 1999 to 2002 or have yours programmed for those years, add the wires for the DBC throttle body, and add the A/C request wire to your harness, because they had a normal request line rather than the serial data type request. That being said, if you want to keep the DBW, I know some SUV's had DBW starting in about 2000 that would also have the A/C request line. The problem then becomes a TAC module incompatibility problem, I think, but am not positive about it, so it may work.
Or, I was told that some 2004 Express vans had an option of DBW (option code JL4) and that they have a regular A/C request line like the 2002 and older trucks. So then all you would have to do is flash your PCM to a van OS and it should work. I have the wiring diagrams to back this up, A/C request line and DBW, but the wiring from the TAC to pedal on the van only has 6 wires, where as the truck has 9. I have been told that shouldn't be a problem as long as the TAC and pedal match. This is where I am currently, but now the PCM tuners I have talked to say that vans DIDN'T have DBW until 2005. I haven't seen a wiring diagram for a 2005 Express van yet, so I'm not sure what they are using to control the A/C, but I am looking into it. If they didn't use the serial data, then this may be the way to go.
It is kind of like the car demand signal powers up the clutch but the PCM gets to decide if it wants to let it run based on head pressure in the system.
I guess I can try it and if it doesn't work, I will have to fall back to a stand alone AC system.
So I called S&P and talked to Mark.
He says that he runs the AC as a seperate system for this
configuration of motor to avoid the problem with having to have a
seperate HVAC module to signal the compressor to turn on.
He went on to say that the idle control isn't very noticiable with
the compressor turning on and off. To mask a little bit of
bogging, he recommends bumping the idle up 50 RPM over factory in
the PCM.
He also recommends the fans not be controlled by the PCM, but by a
seperate fan controller with the temp sensor at the bottom of the
radiator set to about 175F. He said with this setup, the fans will
run about 50% of the time. So basically, if there is 20F delta
temperature across the radiator, the fan stays off. (he's in
Arkansas - it might run a little more in Phoenix!)
The controller he's recommending is on page 134 of the Street and
Performance .pdf catalog.
Regards,
Phil
http://www.sr510.com/tech/Holden_LS1.pdf
