aftermarket wheels on a 3rd gen.
the fronts you are stuck with what is there. The spacers work, but I wish they were hub-centric. I've used them with no issues in the past, but have swapped back to 3rd gen wheels for the same reason. I plan to be turning at a high rate of speed (someday)
A 4th gen axle swap will allow you to use 4th gen wheels. The axles do not protrude 2" per side so the wider wheels will hit the inner fenders sooner
Brakes swap over to the 3rd gen axle freely, Theres no real benefit to buying a 4th gen axle over upgrading the existing axle for less money
and i found a website for liek $700 you can get the whole front hub assembly brand new and will readily accept 4th gen wheels and i think C5 brake set up...
and anybody running the 02 speedlines with painted spokes? or powdercoated something other than chrome?
I have 4th gen f-body brakes on my 3rd gen 'vert. LS1 front and rear brakes. Yes, they will bolt on with a little fabrication and the right adapter brackets. You already found the site that'll sell you them ready to bolt on.
My 3rd gen rear had disc brakes, so it was just a matter of bolting on the ls1 rear brakes and rotors and after modding the e-brake cables, the e-brake works!
Both rears are the same strength wise.
If you have a drum brake rear, it might be easier to go with a 4th gen rear axle....
http://www.thirdgen.org/4thgenrear
http://www.thirdgen.org/ls1reardisc
You will still need spacers to run a 4th gen offset wheel
If you plan on upgrading later, dont bother swapping rears
