Ls6 Engine Harness
Old Mar 5, 2010 | 07:44 AM
phatspeed's Avatar
Default Ls6 Engine Harness
Can i use a speartech ls6 engine harness with a 2005 GTO transmission. Or can it be made to work?
Old Mar 5, 2010 | 10:00 AM
Jones'n's Avatar
If the harness is setup for an automatic (I'm assuming you mean a GTO 4L60E), then it should work fine.
Old Mar 5, 2010 | 10:31 AM
the_merv's Avatar
Veteran: Air Force
What is the Speartech Harness designed for? What do you have?
Old Mar 5, 2010 | 01:04 PM
phatspeed's Avatar
Sorry, the speartech is designed for an ls6/ls1 motor. Just wondering if the sensors on the ls1 t56 trans are that much different than the senors for the GTO t56(Mn12)?
Old Mar 5, 2010 | 03:02 PM
the_merv's Avatar
Veteran: Air Force
Same Sensors.
