Wiring question and convert my mechanical fan into electric fan
Old 03-07-2010, 03:24 PM
gazgab's Avatar
Default Wiring question and convert my mechanical fan into electric fan
Hello,
I start to swap an LQ4 which come from chevy truck express 2004 in a Corvette C3 with 4 manual speed.
I've got any questions about wiring. It's a green and blue wiring, throttle by cable and ECM serv n° 12586243.
1°) I don't understand "STARTING / CHARGING SYSTEM" in my harness: what is it? can I disable it?
2°) I would like to change mechanic fan to electric fan. How can I do it
After 1 working day: my engine wiring :
Old 03-07-2010, 03:56 PM
aknovaman's Avatar
Alternator output 'can' be controlled by the PCM. Leave the alternator wires as connected in your harness. It worked fine in the factory config, so why delete/change it.
Electric fans can be controlled by the PCM just get the F-body schematics from the FAQ and wire them up. Be sure to have your tuner endable them in the PCM file.
Old 03-07-2010, 04:15 PM
gazgab's Avatar
Ok for the Alternator output, but there are an wire alone. (n°39 in blue plug) what is ti?
Old 03-07-2010, 04:48 PM
fptransport's Avatar
to change the mechanical fan all you need is a mechanical fan if, and only if your engine has the threads on the water pump shaft....
Old 03-07-2010, 08:45 PM
LS1MCSS's Avatar
I think he wants to go from mechanical to electric fans.
Old 03-07-2010, 08:58 PM
aknovaman's Avatar
Blue connector pin #39 goes to starter system.
You don't need it.
Quick Reply: Wiring question and convert my mechanical fan into electric fan
