cts-v t56 swap
Old Mar 8, 2010 | 06:12 PM
johnrodz's Avatar
Default cts-v t56 swap
I have a 2005 cts-v engine with t56 6 speed . I am swaping it in to 55 chevy . I need information on shifter placement .I do not wish to use the cts-v shifter ,It sets to far back . Is there a custom shifter made to bolt up to the top of this transmission I need part numbers and supplyer info for this swap has eneyone done this swap , Maybe not in a 55 but Chevell , Corvette, Camaro HELP.... johnrodz
Old Mar 8, 2010 | 06:33 PM
scatillac's Avatar
You're in luck! The Keisler forward-mount shifter will work in the V M12 T56. It has the standard "Hurst" configured shifter stub too!
It's actually easier than the conversion of a "regular" T56, as you don't have to cut the shaft. The M12 shaft changes sizes at the shifter cup. The shaft going to the V M12 reverse lockout is smaller than the regular T56 shaft so you have to have a sleeve made that will adapt it to the Keisler shifter cup's rear hole.
You have to make sure that the pin hole in the M12 rear shaft establishes the correct relationship between the reverse lockout blade and the solenoid.
Old Mar 8, 2010 | 07:21 PM
johnrodz's Avatar
Thanks carl / scatilac. i appricate the info .I have been asking all over the forums and thankfully you had just what i needed. go tarheels' johnrodz
Old Mar 8, 2010 | 07:56 PM
johnrodz's Avatar
I don't supose you have a part number for that shifter ?
Old Mar 8, 2010 | 08:21 PM
Bowtie70SS's Avatar
I had my CTSV 6 speed converted with a GTO mainshaft and a F-body tailshaft.
Old Mar 12, 2010 | 07:54 PM
johnrodz's Avatar
btt btt
Old Mar 12, 2010 | 08:05 PM
bczee's Avatar
I am using a Viper configured T56 for my chevelle with a bench seat.. it has a more forward shifter location that the F-Body.. it should work for your tri-5 also.
Old Mar 12, 2010 | 10:20 PM
the_merv's Avatar
Veteran: Air Force
There is a Shifter that bolts to where the Inspection Plate goes too..
Old Jul 18, 2010 | 04:34 PM
frankv11's Avatar
what or where does that shifter come out of. f dody,gto,after market , keisler?
need help
installing 05 cts v magancharged ls6 w t56 into 69 camaro
need to change shifter and out put yoke to a conventional u joint type
Old Apr 24, 2011 | 08:27 PM
hotrodstingray's Avatar
Default Ctsv t56
Hey johnrodz,
Did you ever got the shifter to work out in your Chevy? I'm about to use the same transmission in my 69 Camaro.
Old Jul 11, 2011 | 11:18 AM
Truckzilla's Avatar
Any info on the changing of the CTS-V output 3 bolt output connection to a standard UJ yoke? I'm trying to do what several of you have done above.
