F-body Radiator Mount Question....
Thanks in advance,
T,
||-------------|| <-----Radiator
U--------------U
|_|_________|_| <----Lower padded "brackets" that it rests inside.
thanks again for the help...
T,
What year car is it going into?
I'm doing a '69 Camaro and am working on that right now. I'm going to cut off the tabs on the rad. support side, so all is left is mostly flat pads. drill a mounting hole in each to match holes I place in the support. Use a little rubber shock mount between the two and use bolts and nuts. Then looking at doing a trim piece on top for looks, when I can!
Tom
As far as the radiator goes, I see it as a proven part, with the 2 fan setup, a low dollar approach to get a running car. Figure I can upgrade later down the road. And I still have lots of little, and a few big, things to still buy before I'm done! Like wheels & tires, driveshaft, steering shaft, gauges, etc...
Tom
T,
Hi Bill,
I have original oses, just don't know how they will line up but should know by tomorrow. The LS1 radiator is wider than stock, but still very doable. no problem with the height of it. If I get past my own little screw-up on mounting it, I should have it done and will do some pics, if that will help. Good thing using tis radiator is that it is cheap, very light, and made for the system.
Tom
Tom
Do you still have the battery in the original location in the engine bay? If so, is the radiator going to cause problems with the battery? I like the idea of the fans and radiator from the f-body if I can get it cheap
I'm going to start with the battery in the original location. I will have to trim about an inch off the side of the battery tray, which won't hurt, the tray is for the old 24 series battery. Will eventually move to the trunk, so not a big deal. Will do some pics tomorrow and post them for ya. I'll try to find the seller on ebay where I got my radiator and fans for $145 + s/h, not to shabby. I also got an underhood harness for $35 and am using the fan relays & fuses, and try to adapt a few other relays.
Got sidelined today! For being so far north, we had no winter to speak of, 8" of snow was the most we had on the ground. Of course last night a nice cold front hit, 2" of snow, most already melted, but wasn't able to finish the rad. support so I could mount the radiator.
Getting my propane heater fixed to get some warmth in the shop so I can move forward. If I don't get there tonite, I'll do some pics ASAP tomorrow and post them. From the mock-up, it looks like everything will work just right.
Getting real itchy to get this thing done and on the road, just waiting on a lump of $$$ to get the remainder of stuff to finish her off!!!
No rush, just when you get time. Could you also get a pic of the wire harness for the fans?
thanks again
ps
sorry to get off your topic Tom
