LS/T56 into 3rd Gen with T/A Relocation Crossmember
I'm looking to stick my 408/T56 into a 3rd Gen, I plan to use a LS Converison K-member to where the Engine would be in the stock location as the 350, so the Tranny would stay in the stock location too.
UMI sells this here..
![](http://www.umiperformance.com/catalog/images/large/2232a_LRG.jpg)
http://www.umiperformance.com/catalo...roducts_id=300
It's for a TH 400..I want to swap in a T56. From the look of things in the pics the mounting poing on the T56 is about 2-3" forward of the mount on the TH 400. I know the T56 is a couple of inches behind the 700R4.
This is the one that UMI sells for the 700R4..
![](http://www.umiperformance.com/catalog/images/large/2228a_LRG.jpg)
http://www.umiperformance.com/catalo...roducts_id=298
From what I have found this is where the Mounting point on the TH 400 is when compared to the T56..
![](https://ls1tech.com/forums/attachments/conversions-swaps/221936d1268857312-ls-t56-into-3rd-gen-t-relocation-crossmember-t56.jpg)
Anyone have any ideas on which one would work the best?
If need be I could tweak it with some flat steel..it would be nice to get a good idea on which one would be better to start with. From the looks of it, it looks like the Mount will end up in the center of that cross-bar so the TH 400 one would be better.
i have the dimension of the bell to trans mount for a short shaft 400 somewhere at the house, ill update when i find it. Are you planning on welding onto it if the mount is off?
http://www.thirdgen.org/techboard/lt...s-lsx-t56.html
Get this and weld a plate on it for the TA mount
Your exhaust routing will be... interesting with the UMI piece
