LS2 wiring and cooling question
Old Mar 17, 2010 | 11:40 PM
kochevy67's Avatar
Default LS2 wiring and cooling question
I was hoping someone could answer my questions.
1. I was wondering if the small fitting on top of the head that has a hose which crosses from side to side could be removed and plugged like the two in teh back near the firewall. These are the fittings that are at the front of the motor and seem to connect the cylinder heads, probably to prevent a hot spot or to help with air pockets.
2. I am installing an LS2 from a 2006 GTO in my Chevelle. There is a white square plug in the harness near the computer connection, it has 13 wires going into it and I have no idea where it goes. I am running the factory harness and have everything accounted for except that. I think it may be for the factory gauge cluster but I am not sure. The plug is about 1in. and 1 1/2 in.
Thanks
Old Mar 18, 2010 | 07:59 AM
98SuperchargedLs1's Avatar
any pictures? i have a 65 fully custom chevelle and finishing it off with a ls2/built 4l80e, speartech harness and turbo should be done in a couple weeks
Old Mar 18, 2010 | 08:05 AM
TomM's Avatar
Thanks
1. Some guys block it off with no problem, I ran mine just to be safe. It is a steam bypass to do exactly what you said. GM thought they needed it, so why change it...just my opinion though...
2. The white connector goes to the body harness for gauges and other functions...
T,
Old Mar 18, 2010 | 11:40 AM
kochevy67's Avatar
Tom thanks for the information. So I can leave the coolant line. As for the white connector should I just leave it under the dash unhooked?
Old Mar 18, 2010 | 12:29 PM
TomM's Avatar
You will need to use some wires from that connector...see the link below for Pockets write up on what to do with some of them...
http://www.thirdgen.org/techboard/lt...rt-finish.html
T,
Old Mar 18, 2010 | 12:58 PM
Pocket's Avatar
I wrote an abridged version thats a bit more general than the first one. Same content though, with a few extra common problems
http://www.thirdgen.org/techboard/lt...revisited.html
It seems like the OP isnt reworking the harness, but using as much factory stuff as possible. Nothing wrong with that, it just makes the links above not so useful. He'd need the GTO connector pinout, unless he plans to trace each wire against every PCM pin
Im not sure where to look for that as GTO stuff isnt as common as Fbody or trucks. Got an AllData subscription?
