carb intake and map sensor ideas?
Your carb should have an unported vacuum port also. Like said above just run a vac line to it anywhere. I hooked the sensor to a small sheet metal tab I hung off the coil pack mount then ran 5 inches of vac line to it.
If you can hook some type of rubber grommet into the side of that intake you can probably just plug the sensor nipple straight into it.
Here's mine using an old rubber elbow from the spare parts box:
