VSS vs. vehicle speed signal?
I'm adding a vehicle speed sensor (VSS), pin 20, 21, to my manual trans 02 LQ9. I had occasional stalling problems without it. Since it's DBW, I thought I might as well add cruise control.
The schematics show a "vehicle speed signal" (C2, pin 50) is needed for cruise control. What's a "vehicle speed signal"? Is that simply the output to the speedometer? And is it needed? I'm running a cable driven speedo.
Yea that is the Speedometer Signal..C2 Pin 10 is the one for the Tach.
It also goes to the Cruise Module to tell it how fast you are going.
Check it out..
http://www.lt1swap.com/pictures/12_b..._radio_vss.gif
Check it out..
