conversion harness?
Old Mar 25, 2010 | 03:18 PM
brad22486's Avatar
Ok now to doing the fuse thing. what all wires go to a fuse block, is there wires that go from the pcm to a fuse? stuff like that. and if i were to go to a junk yard what vehicle would i be able to take a fuse box out of and use?
Old Mar 25, 2010 | 07:04 PM
Pocket's Avatar
Pretty much anything EFI with two INJ fuses
The PCM shares it main IGN fuse with the MAF and has a separate batt 12v constant fuse which is shared with the fuel pump relay
Old Mar 26, 2010 | 12:29 PM
brad22486's Avatar
ok i got a fuse block out of a lt1 z28 will that work?
Old Mar 26, 2010 | 12:47 PM
the_merv's Avatar
They work good..that's what I'm using. I have 8 Fuses and 3 Relays running everything Engine related.
Old Mar 26, 2010 | 12:56 PM
brad22486's Avatar
k sweet got it for 13 bucks so im glad its gonna work
Old Mar 28, 2010 | 08:58 AM
brad22486's Avatar
does anyone have a pic of the lt1 fuse box and a description of what they do. and tell me what wires go where to it
Old Mar 28, 2010 | 09:02 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Speartech Fuel Injection Systems (site sponsor)
http://www.speartech.com
Phone number: 765-378-4908
3574 East State Road 236
Anderson, IN 46017
There's also Tech Rods out of Texas (not a site sponsor)
Old Mar 28, 2010 | 09:04 AM
the_merv's Avatar
What do you mean..if you are adapting it then you will have to kinda wire it yourself. I re-wired my whole Fuse Box to run everything of mine.
Old Mar 28, 2010 | 12:05 PM
brad22486's Avatar
ok do i run the pink from the injectors to the relays? im confused cause ive never done this and i dont know what wires to run to what fuses that kind of stuff
Old Mar 28, 2010 | 01:35 PM
Pocket's Avatar
12v IGN side of the injector connectors go to the fuse block
Old Mar 28, 2010 | 01:58 PM
brad22486's Avatar
u wouldnt b able to send me a diagram for it would u i have to c it done to be able to do it thats how stupid i am at this
Old Mar 28, 2010 | 09:41 PM
  #32
Pocket's Avatar
Please make an attempt at spelling, reading that post is rather difficult
Diagrams
http://i150.photobucket.com/albums/s...s/99-03LS1.jpg
http://www.lt1swap.com/pictures/8_fuel_injectors.gif
Old Mar 28, 2010 | 10:17 PM
  #33
fptransport's Avatar
I went to pep-boys and they have a small fuse box that holds 4 fuses each, I bought 2 of them for about 3.00 each, I then got the pin outs and followed the directions at the above link lt1swap ,works great, dont look too bad, good luck
