conversion harness?
Trust me, all it takes is a bit of patience, proper diagrams and time. The least expensive harness I have seen was $400 and didn't include everything I needed. I can read a lot of schematics for that kind of cash. I laid everything out on the driveway, set my schematics under a rock, grabbed a cold drink and my wiring tools then went at it. Honestly most things you do are removing excess wires. For my setup I had to add a few and change injector plugs but it was not a big deal.
Besides you have us to ask questions of...
Many of us traversed the waters alone.
I'm sure I am not the only one who has discovered more available information after I completed the swap than I knew existed before. That just makes me smarter next time.
You shouldnt have to figure out any wattage or anything like that. Reuse stock size wire being 18-20ga. Use all 18ga if you're unsure, TXL jacket. Fuses should be stock size, you shouldnt be rearranging them or assigning more/less duties
lt1swap.com has a good walkthru for what wires are keepers/tossers in most conversions
oh ye3ah, and dont worry about 16 ga, thats not a problem. as long as its not too small a wire, you're fine.
HO2 pink and blk are for the heaters. Pinks go to the emissions fuse (10A). Blk goes to ground
Oil level wiring gets deleted (pan 2 wire connector). Oil pressure is a single wire connector on the rear china wall and goes to your gauge
Green wire from the 98 CTS goes directly to your coolant gauge
MAF IGN is usually shared with the PCM IGN fuse (15A). Balk is ground once again
Anything else?
