temp sending unit
Old Mar 21, 2010 | 08:28 PM
Redrumls's Avatar
Default temp sending unit
I have a 6.0 in my 68 camaro and need some kind of adaptor for the old style sending unit or a retrofit one (the one for the side of the head). any info would help or point me in the right direction, thanks.
Attached Thumbnails temp sending unit-photo-52.jpg   temp sending unit-photo1.jpg   temp sending unit-photo-2.jpg
Old Mar 21, 2010 | 08:42 PM
Tony C.'s Avatar
Call street & performance 479-394-5711 ask for mark,thats where i got mine from.
Old Mar 21, 2010 | 08:49 PM
Redrumls's Avatar
Wink
Thanks, I'll do that.
Old Mar 21, 2010 | 09:15 PM
fptransport's Avatar
you can also buy them from any hydraulic place you have locally,,, I am looking for the thread size, I think it was a 16mm NPT to 1/4 NPT ...
Old Mar 21, 2010 | 09:24 PM
Tony C.'s Avatar
Sounds like oil sending size, mine was 16mm to 1/8 . They have your size also.
Old Mar 21, 2010 | 09:48 PM
I dont remember tony... I know it was a 16mm to whatever the size of your sending unit is. as mention b4 i got mine from a local hydraulic hose shop lot cheaper just my .02
good luck
also jegs and summit sell them from autometer products...
Old Mar 21, 2010 | 10:12 PM
G-Body's Avatar
sawzall wielding director
The temp sender hole in the head is 12mm x 1.50
The oil pressure is 16mm x I believe 1.50 but don`t quote me on the pitch.
Old Mar 21, 2010 | 10:26 PM
Redrumls's Avatar
thanks, ill check into all those. Also, do i need a 400 ohm resistor for my alt.?
does my idiot have resistance?
Old Mar 22, 2010 | 09:05 AM
Pocket's Avatar
470ohm, but yes you should use it to prevent cooking the alt
Old Mar 22, 2010 | 10:21 AM
Redrumls's Avatar
where exactly do I put this 470 ohm resistor? I don't want to burn up this alt.
Thanks
Old Mar 22, 2010 | 10:42 AM
eatlead's Avatar
autometer makes adapters for it for their oil sending unit.. which converts metric to sae
Old Mar 22, 2010 | 10:54 AM
claytonisbob's Avatar
I'd use a light bulb instead of a resistor (that is if these are like the CS and SI alternators). I just put it under the hood inline of that trigger wire.
Also, I know I'm going to run into this same issue soon enough. I'm thinking of just finding a brass metric adapter that is close to what I need, drill out the center hole to 1/4" or whatever and just tap it to the standard thread I'd need.
Old Mar 22, 2010 | 12:46 PM
LS1MCSS's Avatar
I am going to guess that your 68 probably uses a sender with 1/2 npt threads. If so, you wont find an adapter for that. The end of it, that sticks into the head, is too big for any adapter to work. If it's 3/8 npt, see this thread.
https://ls1tech.com/forums/conversio...-approach.html
Old Mar 22, 2010 | 01:27 PM
forcd ind's Avatar
i thought the adapter i got from S & P had a large body, either 3/8 or 1/2, i'll have to ck
Old Mar 22, 2010 | 07:47 PM
LS1MCSS's Avatar
If the mid 80's sender uses the same ohm measurements, I can cut and thread one for him, so it screws straight in.
Old Mar 22, 2010 | 07:51 PM
Pop N Wood's Avatar
If it is truely a 1/2 NPT you can put it into a block heater plug. Just drill out the hex allen head and thread it with a tap. That is how I installed a Datsun sender.
