Temp Sender cut and thread approach
Old Feb 4, 2010 | 11:13 AM
2Aspire's Avatar
Default Temp Sender cut and thread approach
This is regarding my 86 Monte Carlo SS and the desire to use, among the other stock guages, the stock temp gauge with the LS2 transplant.
First off.. I have been down the path of drilling the head and was looking for an alternative..
I have seen the adaptors but didnt like the fact that the sender would be outside the head due to the difference in size..
Also saw the resistor in parallel with stock style sender but didnt like the curve it produced in testing..
Through this forum I found that LS1MCSS had found that he was able to turn down the stock 3/8 NPT sender to adapt to the 12mm on the LS2 head.
I asked for his help on turning one down and graciously he did.. Thanks!!!
Below is the picture of the end result of LS1MCSS work on my stock sender...
Old Feb 4, 2010 | 07:13 PM
LS1MCSS's Avatar
It only takes about 30 minutes, max, to do one of these. I just leave my lathe set up for it so it's ready.
Old Feb 4, 2010 | 08:54 PM
JJFarmer's Avatar
What do you charge to do that, looks like it's what I might need?
Old Feb 4, 2010 | 09:52 PM
LS1MCSS's Avatar
I do it free. It's not like it's hard work. The hardest part is walking to my shop. It's 300 feet from my house.
Old Feb 4, 2010 | 10:00 PM
JJFarmer's Avatar
Man, that's good of you but it takes up your time. Surely it worth...maybe your favorite adult beverage? PM your way.
Old Feb 4, 2010 | 10:04 PM
huram griffin's Avatar
nice!
Old Jan 13, 2011 | 09:20 AM
johken's Avatar
Is this something you can do to the Autometer sender. NOt the short stubby one that adapts into the adapter. Problem with that one is that it doesnt protrude into the head. The other short sweep sender part #Auto Meter 2258 is longer and wont fit through the adpaters small hole. Can this sender be turned down to bypass using the metric adapter?
Old Jan 17, 2011 | 09:57 AM
FastKat's Avatar
That's awesome - I wish I would have seen this sooner. I paid a rip-off price to get one of these done for my car.
Old Jan 17, 2011 | 11:57 AM
97s10ls's Avatar
How far down to the nut do you mill it to and how many washers are needed?
Thanks
Old Jan 17, 2011 | 01:30 PM
arthropraxis's Avatar
Is it possible to turn down a VDO sender?
Old Jan 17, 2011 | 02:43 PM
LS1MCSS's Avatar
Thanks
I don't cut any farther than necessary and one washer will seal it. If the old threads go all the way to the nut, then I usually cut most of them off.
Old Jan 17, 2011 | 02:44 PM
LS1MCSS's Avatar
I don't know if it can be turned down or not. I would have to look at one and measure it.
Old Jan 17, 2011 | 02:45 PM
LS1MCSS's Avatar
What's the original size of it?
Old Jan 17, 2011 | 03:25 PM
3/8ths IIRC. I obviously don't know anything about this.
If there is enough meat on the sender to turn it down and tap it to fit the thread on the heads, can any sender be lathed down?
Old Jan 17, 2011 | 05:59 PM
Wicked Mayhem's Avatar
i just tapped the head for NPT. problem solved.
Old Jan 18, 2011 | 09:00 AM
rileyridez's Avatar
Is the sender for the 1st gen camaro's the same size as the one for the Monte Carlo SS? Or can it be machined to work. It might be to long. If so can I send you one to turn?
Old Jan 18, 2011 | 09:13 AM
John McGraw's Avatar
What would be the advantage of doing this versus just using the Autometer adapter?
Regards, John McGraw
Old Jan 18, 2011 | 10:21 AM
rileyridez's Avatar
Advantage for me on a 1st gen camaro with factory air is clearance. I don't think I can get the original sendor with adapter in with the factory evap box.
Old Jan 18, 2011 | 01:49 PM
LS1MCSS's Avatar
1st gen camaros used a sender that is 1/2" pipe. It's too big to turn down. The mid 80's sender is 3/8" pipe and might be the same ohm rating, but I can't promise it.
Old Jan 18, 2011 | 01:52 PM
LS1MCSS's Avatar
I saw one a few days ago that had the actual sender part that was too big to fit through the 12MM hole, but the threads were only 3/8 pipe. I wouldn't try to cut it because I was afraid it would cut through before I got it small enough. So the short answer to your question is NO.
