Help 68 mustang 6.0 swap
Originally Posted by [B
BlackTA96[/B];13075395]Search search search search search Search search search
66 mustang 4l60e. i had to remove the factory cross member mounts then i used a rose bud torch to heat floor to make moving the tunnel easier. Also had to make a notch in the tunnel for the trans servo/cooler line connections. We then welded in some 1/8 x 3 in steel strips to reinforce the tunnel where the factory mounts were.
67 cougar ls swap
the swap is not complex at all. I put a ls 1 six speed in my 1969 mustang fastback and it runs strong. Will post pictures and i am not worried what the ford guys think because this is my car and money. It get twenty miles to the gallon, plenty of power and most importantly i can drive it any where without worries of if it is going to break down.if you need help i will give you all the information that i have.
.i'm trying to ls swap my 67 cougar
