LS2 and Vintage Air, How to Wire?! Please help!
A number of folks have run them with success, note ls1nova71's comments above. I do take exception to the purely subjective statement that it doesn't work as well as the Sanden - would be nice if that statement could be quantified.
Something else to consider - I was under the impression that some of the early Truck Vortec compressors are virtually identical to the var d compressor but are fixed displacement - but I have not been able to verify that - if so it would be a possible solution and allow the compressor to be mounted in the factory location (which is what I want to do - I don't want to relocate the compressor).
The consensus seems to be the var d doesn't work with VA systems - personally I think that is a marketing ploy. What do I have to lose but try it and see - if it fails I'll try something else.
By chance do you know anything about the Vortec compressors I mentioned? I ask because apparently the conversion brackets to mount the 508 in the factory location can interfere and require mods to the motor mount because the 508 is longer.
I don't know about them, other than if they were originally on truck motors, you'll need to run the truck acessories because an LS1 bolts up differently, and further back. I made my own bracket to mount the Sanden in the original spot on my '33, but I did move it towards the front some and it now runs off of the main serpentine belt. I did that for motor mount clearance.
Can you send me some pics of what you did? Can send email address via PM. That may be the best solution yet because the rear of my compressor sits pretty close to the headers right now. Is the 508 pulley the same rib count and size as the LS1?
I think the compressor deal is this, at least from what I remember from talking to VA and Hot Rod Air. The Sanden (508) compressor will work better, because of its pumping capacity, but VA instructions also say that the possibility of coil freeze up is likely and also says that if air flow decreases (because of freezing up) to turn down (up) the air cooling temp to defrost the coil.
Hot Rod air swears that the using the stock VD compressor is sufficent and will not damage the compressor and doesn't know why VA says that the VD compressor will be damaged.
I'm using the Sanden, but am buying parts while stationed overseas and that makes knowing what works right the first time, while home once in a while I install some parts, gather data and try to find the right parts.
With my application, my 66 Nova with TCI clip and LS1, I had to modify the VA LS/Sanden mounts and still am not sure I have room for the tensioner pulleys, I think I am going to have to shitcan the mounts and just make my owe and suck the compressor as close to the block as possible, or swap over to a V-belt setup vice serpentine.
I went with the Sanden for another reason (I think, like I said I gather data and try to order as I can) and that was the top hose connections, not enough room for the hoses to rear mount to the stock VD compressor. I already had to notch the frame mounts for the Sanden, and the stock VD touched them initially.
