LSx balancer
Old Mar 30, 2010 | 09:34 AM
Jimbo1367's Avatar
Default LSx balancer
I want to pick up a used balancer and cut off the spokes to use the hub to help installing the timing cover on a 08 LY6. Won't any year 5.3/5.7/6.0/6.2 L engine work? Are these known to wear on the hub at the seal location? Looking at the hub isn't always a option
Old Mar 30, 2010 | 09:39 AM
rao's Avatar
rao
Any hub will work.
I just leave the front cover bolts loose until the hub is fully set, but you have a good idea if you are going to be doing a lot of installs, open up the inside enough to make it just slip onto the crank like set up bearings for rear gears.
Old Mar 30, 2010 | 11:39 AM
Jimbo1367's Avatar
thats what I thought (Car Craft mag)
thanks
Jim
