Difference between the GM 6.0's?
Old Apr 1, 2010 | 06:40 PM
battousai's Avatar
Default Difference between the GM 6.0's?
Hi
I was planning a 6.0 swap in my f-body, and was wondering what the difference is between the 3 GM 6.0 Engines. Just in case, they are the LQ4, LQ9 and LS2.
Old Apr 1, 2010 | 07:00 PM
NemeSS's Avatar
there are more than those listed. but all those came equipped with cathedral port heads.
brian g's Avatar
Check at wikipedi site, don't forget the ly6
Old Apr 1, 2010 | 07:24 PM
Black&White's Avatar
yeah, wikipedia is your friend on that one. the ls2 is the only one of those that is all aluminum i believe, but not 100% sure on that.
out of curiosity, what year/model fbody do you have? and nice user name btw
Old Apr 1, 2010 | 07:29 PM
Bo185's Avatar
Originally Posted by battousai
Hi
LQ4: Gen III, iron block, dish pistons, 9.4:1 317 heads.
LQ9: Gen III. iron block, flat tops, better rods, 10:1 CR, 317 heads
LS2: Gen IV, AL block, flat tops, better rods, 10..9:1 CR, 243 heads
The LQ4 and LQ9 are the same save for the pistons and rods.
The LS2 is Gen IV and will have front mount cam sensor side knock sensors and may or may not be a 24x crank trigger.
Old Apr 1, 2010 | 08:23 PM
battousai's Avatar
thanks for the info, what engine would be best for a N/A application?
'98 camaro
Old Apr 1, 2010 | 08:25 PM
Bo185's Avatar
'98 camaro
Well the LQ9 will bolt right in and has nice CR and you could add the L92 heads and LS3 intake for even more!
Old Apr 1, 2010 | 08:33 PM
battousai's Avatar
well, it wouldn't be a complete bolt in, ive got the sixer. anyways, what does CR mean?
Old Apr 1, 2010 | 08:36 PM
Palomba's Avatar
compression ratio, however i do think in like 2003 the LQ4 got the beefier LQ9 rods as well. Just dished pistons instead, and can generally be found for a few hundred left. But the LQ9 is a nice motor.
Old Apr 1, 2010 | 08:49 PM
Jimbo1367's Avatar
CR = Compression ratio
Check at http://car-part.com/ for a engine. I found my 08 LY6 w/ 30K CHEAPER than most salvage yards wanted fo 40-75K LQ4s or 75-100K LQ9s. If you do score one, snag the ECM too. Remember.... LY6s are the replacement LQ4 but w/ 9.6:1 comp. ratio and the L92/LS3 rectangular heads already installed. Its a no brainer in my book. Cheaper and better.
Here is one guy who did. (his car was a v6 too I believe) https://ls1tech.com/forums/conversio...d-formula.html
Old Apr 1, 2010 | 09:57 PM
battousai's Avatar
Thanks for the read, and the website. and the ly6 advice. you have helped me make up my mind.
Old Apr 2, 2010 | 10:16 AM
Jimbo1367's Avatar
Default glad to help
Glad I could help. Try doing a search from threads started by pillagenburn He has numerous threads and videos on his build. Good stuff IMO
Oh yeah, I WAS wrong . His car was a LT1 car. Not a V6 mybad. LOL.
Old Apr 2, 2010 | 11:50 AM
hpbob1's Avatar
Default LQ9 rods beefier?
Hi Palomba,
Are you sure the LQ9 has beefier rods than the LQ4? I have 2 LSX motor build books and neither one of them says anything about LQ9 rods being any beefier at all. They both say all the LS motor rods are the same powdered metal, then forged rods & cracked for rod cap fit. The 1999 and beyond rods have better factory rod bolts and LS1/LS6 rods have full floating pins. I have heard this beefier rods rumor from someone else but it was just guys talking. Does anyone have any specific written proof etc the LQ9 rods are beefier? No offense. I just l want to know for sure.
Hpbob
Old Apr 2, 2010 | 02:40 PM
Isolde's Avatar
There's a guy on PFF going by battousai, is that you?
Old Apr 2, 2010 | 04:14 PM
Bo185's Avatar
Originally Posted by hpbob1
Hi Palomba,
Hpbob
The LQ9 has the better LS2 rods. In 05 they all went to LQ9 rods even the LQ4 and LS2 . But technically they are LQ9 rods, not LS2 rods, since they were first used in 2003 LQ9's then used in the 05 LS2. But everyone here says the other way.
Been awhile since this came up but there is lots of info here and on PTtrucks.net about it.
Originally Posted by http://www.enginebuildermag.com/Article/1096/gen_iii_gm_small_block.aspx
Rods
This whole family of engines was designed with three different bore sizes and two different strokes, so GM only needed two rods, a long one and a short one, to cover all four different displacements, but they ended up with three different rods anyway. These rods are all powdered metal forgings with cracked caps and they all had press-fit pins, except the ones used in the 6.0L LQ9 engines that came with full-floating pins. And, it appears that all the Gen III/Gen IV motors (a Gen III motor with "displacement on demand" is called a Gen IV motor) went to full-floating pins in '05 according to some car magazines.
The Long Rods
* The 4.8L engine used a "long rod" that measured 6.275? center-to-center because it had a shorter stroke. Look for a 121BW casting number on the side of the cap.
The Short Rods
* The 5.3L, 5.7L and 6.0L all used the "short rod" that measured 6.096?, center-to-center, but there were two different short rods used for the 6.0L engines.
The 5.3L, 5.7L and the standard LQ4 6.0L used the 143 casting that was rounded off on one side of the shank and squared-off on the other side. Our sample rod weighed 609 grams.
The LQ9 version of the 6.0L that was used in the Escalade and Silverado SS came with the 123/145 casting that had a thicker beam, a stronger big end and a bushing in the small end for a full-floating pin. Our sample weighed 645 grams.
The original rod bolts in the 5.7L were more than adequate to start with and they were upgraded to take 450 hp in '99, so they're pretty reliable, but rebuilders should consider replacing all of them with ARP bolts when building a high performance motor.
Just for the record, the only parts from the Gen II engines that were carried over to the Gen III were the rod bearings; they're the same for both families. ]Rods
Old Apr 2, 2010 | 09:16 PM
themonkeyman89's Avatar
So all the Gen III motors have forged rods from the factory?
Old Apr 2, 2010 | 11:16 PM
pillagenburn's Avatar
the gen IV have forged rods; the gen-III LQ4 does not have forged rods If I remember correctly, but they are strong no doubt. I am in the process of finding a shop that can dyno my car, so I'll let you guys know how those numbers come out. It looks like it'll be a Mustang dyno though.
Either way, the LY6 is the clear choice for the even remotely budget-minded. What's not to love? L92 heads, stronger rods, iron block for strength, oh and variable valve timing. Since I've been driving mine on a daily basis, I can tell you that this thing is truly awesome..... it doesn't matter what gear you are in, it always pulls and it pulls REALLY hard.
If I can get 400+rwhp on 89 octane gas then I'll be happy... 9.6:1 compression is such a nice thing Oh, and the other nice thing about the LY6 is the compression... so if a turbo, procharger or TVS is in your future - this is your motor.
edit: oh, and just a big FYI to everyone considering this swap... the ideal candidate is going to be a 1998 f-body or 97-98 vette (or even 1999 f-body I think) - whichever cars of those years that utilize analog gauges plus have the oil pan, accessories and all that stuff necessary for the swap... the same goes for swapping in a L92.
Old Apr 2, 2010 | 11:36 PM
battousai's Avatar
Hmm, There is a local salvage yard that has an engine from a silverado and they say its a 6.0, how could I tell what one it is?
Old Apr 3, 2010 | 12:52 AM
Palomba's Avatar
Vin number of the truck it came from, you can narrow it down by looking at the head casting number. The LQ4 and LQ9 will have a 317 on the heads.
Old Apr 3, 2010 | 09:08 AM
Jimbo1367's Avatar
Default Ly6
Check the waterpump. If the WP is close to the block, its not a VVT. If the wp is away from the block to clear the VVT in the timing cover http://www.mastmotorsports.com/page....Camshaft&id=30 Its very obvious once you see it.
On the front on the drivers side of the block, I believe it says " IV 6.0L " It says the same on the rear of the pass side block. ( bare in mind that this is from memory. So what it says might be SLIGHTLY different.) LY6 or L92 are gen IV motors. The eariest I believe they are offered is late 07 ( new body style)
