dbw not working help please
Old Jan 30, 2013 | 08:30 PM
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Sounds like you have either a bad pcm or a bad TAC module. It is easier to find a PCM to swap out and test.
Its hard to DIY test the two because they have two data communication wires that they communicate over. Being that you lose the data at your OBD port it sounds like you have a short over the data lines on one of the components.
I can send you a PCM to test with, if you send a deposit for it and when you return it you get all of your money back minus the small amount of shipping. This would be the easiest way for you to test, unless you have another tuned PCM to test with.
Make sure that you check the pinouts at the PCM Blue connector to make sure there isnt something pinned wrong on 58 and 59. Both of those are data lines.
You should have an Orange with Black stripe wire on Blue 14 and a Blue with white stripe on Blue 15.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Jan 30, 2013 | 09:14 PM
Jcarlisle's Avatar
Default DBW issues
Thanks for the quick reply, so far that is what we came up with as well. I also forgot to mention that with key on I am getting 12v on both throttle motor wires in my 2 pin connector. Which from what I understand one should be high as the other is low . How much would it cost for deposit ? All wires are confirmed in correct locations. 59 is removed per info on lt1swap.com . Thanks again for your help. Checked out your website already looks like you still working on it.
Old Jan 30, 2013 | 09:28 PM
Jcarlisle's Avatar
Default Dbw issues
One last thing I hear a buzzing type sound coming from engine bay when TAC module is hooked up but can't remember if it goes away when it is unplugged. Guess I will check that tomorrow.
Old Oct 13, 2025 | 02:18 AM
Mendo101's Avatar
Default Hey my friend
I really have been going through the same situation I got the gen 3 throttle body and tac madual and I got the 411pcm I got everything new but it’s still giving me trouble codes i need a good diagram from you, from the 16 pigtail wires and the 6 pin throttle TPs send me a text @ 7072723163 pleas
Old Oct 13, 2025 | 02:24 AM
Mendo101's Avatar
Default Help
