6.0 carbed forth gen.
Old Apr 7, 2010 | 10:51 AM
too tall's Avatar
Question 6.0 carbed forth gen.
Ok i have run in to yet another issue with my 95 camaro v8 ls swap i want to run a carb but i think there will be cowl clearancing problems so dose anyone have a carbed fourth gen. If so let me see some pics of how you made it fit if you dont mind.
Old Apr 7, 2010 | 06:42 PM
too tall's Avatar
nobody ??
Old Apr 8, 2010 | 06:29 PM
NemeSS's Avatar
u will need a cowl hood regardless with carb. even with sbc ot carbed lt. the car will need hi rise hood
Old Apr 11, 2010 | 10:19 AM
RS2SSxLS2's Avatar
Do you have the swap done yet and if so Id love to see some pictures?
Old Apr 11, 2010 | 11:02 AM
blk96406's Avatar
Ive got a carb'd 6.0 in mine....... First thing I did was pulled the plastic cowl trim off/hood off, put the motor in, intake on, and then set the carb back in there and "marked out" where I needed to cut. I cut the cowl a little big so if I ever go to a Dominator or something, I have plenty of room. I "trimmed" the plastic a little on the "tight" side, so it if that day ever comes, its just a matter of trimming plastic. I also ditched the wipers, and made a couple plates to cover up the vents/seal the cowl back up where I cut to box it back in. Right now, Ive got a Vic Jr/950HP, the stock hood DOES not fit, so plan on an aftermarket hood, I picked up a Glasstek 4" cowl hood. The hood itself has to be cut too, there is a support that goes from hinge to hinge underneath right where the carb sits. Ill dig around through my pictures, Im pretty sure I snapped some up, but the camera died around that time, and I dont know if they were on the old one or the new one.............
Its really not that bad to do, just time consuming....... and the old saying "measure twice, cut once" definitely comes into play
Old Apr 11, 2010 | 03:57 PM
too tall's Avatar
i got a deal on the 6.0 im gitting the ecu, harness and full front acc. so i guess im going efi will the truck intake fit ?
Old Apr 11, 2010 | 06:36 PM
blk96406's Avatar
Nope. 98% sure (Im sure others will chime in if Im wrong ) that it wont fit, and the accessories are all different to the fbody specific stuff too, oil pan too.....
