Do I need VSS with TH400?
Old Apr 8, 2010 | 12:20 AM
jej's Avatar
jej
Default Do I need VSS with TH400?
I have a 78 Chevy K30 crewcab with a 5.3 fuel injected engine in it. It is drive by cable and has a TH400 and a NP203 transfer case. When I modified the wiring harness for a stand-alone engine, I removed all the transmission wiring since I was using a non-computer tranny. My speedometer is cable operated and I don't have any working cruise control (I don't know how to set it up, anyway). The truck is currently running. I recently read that i need to have a VSS for the engine to run properly (get good fuel mileage and power). Is this true? If so, how do I go about hooking up a VSS on the Th400/NP203 and what do I need to do to get the computer set back up for it? Any help would be appreciated. Thanks
Old Apr 8, 2010 | 03:11 AM
code4's Avatar
I don't see why you would need it. I know fuel & power can be altered regardless of VSS.
I run a t400 on my camaro, i use the front abs sensor just so I can get the factory speedo to work.
Old Apr 8, 2010 | 06:33 AM
Pocket's Avatar
It helps to prevent stalling when stopped and gives small improvements all around. Some think it can be tuned around, but why bother
Use an inline cable to electric adapter. JTR is the most common and has the best info about it, but multiple companies sell cheaper units
Old Apr 8, 2010 | 12:54 PM
jej's Avatar
jej
Thanks for the replies. I will look into the sensor from JTR. I guess I will have to figure out what pins to use on the computer.
Old Apr 8, 2010 | 05:40 PM
gofastwclass's Avatar
Dakota Digital makes the part you need as well. Just another option.
