clear powdercoat
Old Apr 9, 2010 | 10:38 AM
Jimbo1367's Avatar
Default clear powdercoat
I am getting a new oilpand and beadblasting my timingcover/valvecovers and want to have it all powdercoated. My question is I want to maintain the stock new look of the cast aluminum , so should I go with " flat clear" or "semigloss" (satin, I believe some call it)
thanks,
JIm
Old Apr 9, 2010 | 10:39 AM
Jimbo1367's Avatar
semigloss clear
Old Apr 9, 2010 | 01:12 PM
Nashty's Avatar
It will still darken it like it's wet. Might not notice, or then again, maybe you will.
Old Apr 9, 2010 | 01:43 PM
Jimbo1367's Avatar
Default clearcoat
Which will darken. Semi or flat?
Old Apr 9, 2010 | 03:51 PM
Jimbo1367's Avatar
c'mon people. I know someone know the answer.
Old Apr 9, 2010 | 03:53 PM
Bowtie70SS's Avatar
I have not seen the powder coat darken on stuff I have done in clear. The powder coat is whitish when sprayed on and it is dry. I would use satin if I were you. Get 70% or something close.
Old Apr 9, 2010 | 07:06 PM
Hotrod406's Avatar
I just clear powdered a valley pan and it is quite a bit darker than it was before. I used super gloss clear because that's what I had. I think satin or flat will work fine. Maybe your coater will have a sample of both?
Old Apr 9, 2010 | 10:01 PM
Gray86hatch's Avatar
A clear anodize will maintain a as cast color and provide corossion protection.
Tim
Old Apr 10, 2010 | 09:08 AM
Jimbo1367's Avatar
Default where
Tim
Is anodizing pricey? What type of vendor will do this? I was thinking of asking for samples of clear pwdr coated cast aluminum items, but they would need to be on a running engine for heat cycles. If the clear anodizing is too pricey ( I am thinking it will be ) I will have to settle for a cast aluminum powdercoat or just not bother until they all discolor enough to bother me. Hopefully a couple of years at least.
Old Apr 10, 2010 | 09:09 AM
Jimbo1367's Avatar
Default valleypan
do you have any pics of it?
thanks,
Jim
Old Apr 11, 2010 | 12:55 AM
shovelhead73's Avatar
All th clear powdercoats will darken the finish, gloss or semi-gloss. I've tried both. I think heating the aluminum to 400+ degrees does somehting to the finish. You might try taking it to a body shop and have them shoot your pieces with a couple coats of clear.
Old Apr 11, 2010 | 07:06 AM
Jimbo1367's Avatar
Anyone have any pics of cast aluminum pieces powdercoated "cast aluminum"?
thanks,
Jim
Old Apr 13, 2010 | 05:18 PM
Hotrod406's Avatar
Here are some pics of that valley pan I coated. That was sand blasted and then coated. I'm doing a brand new front cover right now. I will post before and after pics of that one.
Brand new front cover
Cover is on the oven curing right now. I'll post a pic when it is cooled off.
Old Apr 13, 2010 | 05:49 PM
Jimbo1367's Avatar
Default powdercoat
[B][Hotrod403/B]
Thanks. After you sandblasted the valleycover, did it look like a new cover or did the sand discolor it some? Did you p/c the valley yourself too? Eastwood products? thanks,
Jim
Old Apr 13, 2010 | 06:27 PM
Hotrod406's Avatar
The sandblaster didn't color the metal but it puts a different finish on it than original. It looks like sand paper instead of smooth. I think that's why it got so grey. It almost looks like colored powder but it's clear.
The front cover is cooled and I got a couple pics. You can see that it got a little greyer but not as much as the blasted cover. I think that's the difference between blasted and not.
Old Apr 14, 2010 | 06:50 AM
Jimbo1367's Avatar
Hotrod406
thanks for the update. Yeah, there is deff. a difference. The new one looks more natural. (except for the gloss)
What level of gloss did you use?( semigloss or gloss)
thanks,
Jim
Old Apr 14, 2010 | 08:23 AM
Hotrod406's Avatar
I'm using the supergloss from Eastwood.
Old Apr 14, 2010 | 08:28 AM
Jimbo1367's Avatar
ok, thanks
