two problems i can't solve!
Old Apr 13, 2010 | 07:59 AM
V8 FC's Avatar
Default two problems i can't solve!
ok i have an ls1\t56 in my rx7. everything was fine until i took it to the shop to get the exhaust welded. I got home and i noticed my volts gauge was hanging around 12 volts. that was last monday, i went to start the car on sunday and it was a tough rough start. i hooked up a volt meter to check the exact number and it was at 11.59 with the motor on. i reved it up a little and saw my volts drop down to 11.37 back to idle back to 11.59. I turned the car off and took the altenator off took it to a starter and altenator shop and they let it run for 5 mins and it was give an output of 14.6 volts. came home checked the signal from the pcm to the altenator and it was reading 11.53. what could be wrong here? i have a ground from the frame to the motor and its actually on the altenator bracket.
the motor is from a 2002 vette, trans 2001 f body, wiring harness and pcm is from a 98 fbody (i found out to late that the 98 harness and pcm is not the best) again everything was working perfect until i had the exhaust welded at the shop
problem two
i have a nice sqeaking sound coming from somewhere and i can't put my finger on it. I thought it was my belt so i took the belt off started the car and it was still there. i only let the car run for like 10 seconds with the belt off. Now i followed the steps from ls1howto.com on how to put the front timing cover on because i changed my seals on the timing chain cover and i had to change my crank pulley from a vette pulley to an fbody pulley. the sound is coming from the front of the motor for sure but i can't tell from where. the odd thing is if i rev the motor the sound doesn't change i stepped on the clutch the sound doesn't stop so its not the throw out bearing. and its now a bearing issue because i have at idle on the oil pressure gauge between the 25 and 50 on my autometer gauge and when i rev it up it goes to 50 so i don't think its a bearing in the motor. any ideas?
Old Apr 13, 2010 | 08:09 AM
usmcz28's Avatar
Issue # 1
If they didn't disconnect the battery and the PCM prior to welding they may have fried the diodes in the alternator or damaged the PCM charging circuit. Generally when you start welding you want to disconnect the battery and pull the PCM to prevent this. When they ground out the welder on the frame or another ground point on the car to start welding you can blow some **** if it's not disconnected.
Issue # 2
Could be the alternator bearings or the oil pump is starting to die.
Old Apr 13, 2010 | 08:16 AM
V8 FC's Avatar
Originally Posted by usmcz28
Issue # 1
Issue # 2
yeah i am not sure if they took the battery off line i have a battery kill switch i should of turned it off before i rolled it in the garage but the signal is there with the key on. i took the one wire plug on the top of the altenator off and tested for volts and it was reading 11.53 so it is sending a signal.
for issue to it can't be the altenator bearing if i took the belt off and its still making the sound. but the oil pump might be it i have never heard an oil pump die before so i am not sure of the sound
Old Apr 13, 2010 | 11:03 AM
Pop N Wood's Avatar
If your alternator checked out at the alternator shop then it is probably OK. Maybe something got disconnected or shorted to ground when the shop did the exhaust. Do some continuity tests on the alternator wiring.
It might be a stretch but I wonder if your low voltage issue could have anything to do with the oil pressure gauge being off? Maybe check it with another guage?
Old Apr 13, 2010 | 01:31 PM
dpd069's Avatar
I seem to recall having the same alternator problem. I believe you have to have the charging indicator light in the circuit for it to start charging. Either that or a resistor.
Old Apr 13, 2010 | 03:49 PM
NO CATZZ's Avatar
You need to provide +12VDC switched to the alternator exciter circuit. I can't remember which pin it is on but it is 3 or 4 pin connector on the back of the alternator.
Old Apr 14, 2010 | 12:43 PM
V8 FC's Avatar
i took off all the gauges from there sources just to check and see and still the same results, i did how ever plug the gauges back in and the oil pressure went right up like normal. so i am not sure. as for the continuity test on the altenator wiring what should i see there? i was told about adding a resistor to the wire but i am not to sure what to look for yet
what did you do to fix your problem?
well the wire is getting 11.53 volts as of right now, i am sure its wired right only because i am using the gm harness and it did work on the old altenator.
Old Apr 17, 2010 | 07:04 PM
V8 FC's Avatar
ok so i was cleaning the garage and i looked at my fc and i said ok let me give it a little TLC and see whats going on. i traced every wire i could think of. but before i did that i checked my battery i had it on the charger since sunday and i took it off the battery tender on wedsday and i got a reading of 13.22 unplugged the battery tender from it and checked it today and i had 13.25 so that means the battery is holding a charge thats a good thing for me. So after tracing my wires i couldn't find anything wrong with it. So i took the ground off that i had on the driver side and the motor didn't start, we all knew that was going to happen. So i put on a new(newer) ground from an old sound system i took out. Its a 0 gauge ground wire hooked it up to the frame of the car and to the alt bracket where the 15mm bolt is it started right up and i got this as a reading!
one problem down one more to go!!
Old Apr 17, 2010 | 07:07 PM
V8 FC's Avatar
ok so today since i fixed my alt i was able to let the car run for a while and i went under the car and it sounded like it was coming from the crank pulley. So i turned the car off and i took a wrench to the crank bolt and with almost no force the bolt came right out. so i said to myself let me see if the sound is still there. started the car and the sound was gone! so i ordered an arp bolt should be here this week!!
Old Apr 17, 2010 | 08:00 PM
awd-rwd racer's Avatar
lol glad you figured your stuff out. when are you gonna take the beast for a ride?
Old Apr 17, 2010 | 09:28 PM
V8 FC's Avatar
well i ordered that new arp bolt and ordered a new crank pulley i don't want to take any chances. i am going to wire up the gauges put my interior back together and hope for next weekend to be out having some fun!
Old Apr 18, 2010 | 09:00 AM
rotor vs. piston's Avatar
Awesome... doing my gauges today.
Seems there's to much confusion as to the charging issues w/ these swaps. I'm hoping that the resistors in line w/ the charge circuit to the alt w/ square away my charging and amp draw issues.
I'm hoping to have this as a potential DD by june, should be road testing w/in the next week.
Old Apr 19, 2010 | 10:17 PM
V8 FC's Avatar
good luck with yours man i have not touched mine since sunday when i fixed the charging issue. i am going to try to work on it this week i want to go to a big event this weekend
Old Apr 20, 2010 | 05:26 AM
poconojoe's Avatar
Get to Somic early, I don't see where they're going to have room to be parking many cars
Old Apr 20, 2010 | 09:07 AM
73 nova guy's Avatar
are we talking about the pocono sonic?
Old Apr 20, 2010 | 07:59 PM
whats going on at sonic?
Old Apr 20, 2010 | 08:18 PM
V8 FC's Avatar
i wasn't planning on going to sonic at all its another car club event i wanted to go to but it looks like i will be taking my bike there..lol and ryan its not the pocono sonic its a sonic near philly
Old Apr 21, 2010 | 12:01 AM
i herd about this one near philly. i thought about going to the one near me but not likely ill make it.
Old Apr 21, 2010 | 05:21 AM
poconojoe's Avatar
Pocono Sonic is Saturday, the other one is Sunday
If you have facebook
http://www.poconosonicmeet.2ya.com/
The other one is in Morgantown,PA
Old Apr 21, 2010 | 09:30 PM
V8 FC's Avatar
lol why i would i go to a truck meet..lol but thanks
