can i use the variable compression A/c compressor?
Old Apr 13, 2010 | 07:51 PM
bfrank79's Avatar
Default can i use the variable compression A/c compressor?
i need to know from somebody who knows or has tried it, whether or not the factory a/c compressor from my 6.0 will work in my 79 C10.
Old Apr 13, 2010 | 11:43 PM
G-Body's Avatar
sawzall wielding director
Should work ok. I`m using the LS compressor with my 85 el camino system and getting ready to use one on my brothers 78 buick. Might not be as efficient as the original system was, but it works.
Old Apr 16, 2010 | 01:36 PM
bfrank79's Avatar
did you have to notch the frame to fit it?
Old Apr 16, 2010 | 07:33 PM
bczee's Avatar
Yes it will work, question is how well. I have a LS1 compressor only in my 71 Chevelle AC System. it work ok. util i get in bumper to bumper and slow traffic.. then it only starts to blow cool air.. but everywhere else it's just find.. could be better.
Search for that artical to convert your compressor to fixed and it will work a bit better. Else it will be at about 60%.
Old Apr 16, 2010 | 11:14 PM
G-Body's Avatar
yep a little notch. No biggie, didnt even have to break out the sawzall, just the cutoff wheel and welder lol
Old Apr 18, 2010 | 05:13 AM
509stroker_ace's Avatar
you could also look into kwikperformance's conversion kits to change the mount of the a/c
Old Apr 18, 2010 | 05:41 PM
bfrank79's Avatar
is there any way you could put i pic up of the notch you made? it would help me alot
Old Apr 18, 2010 | 05:42 PM
bfrank79's Avatar
yea im trying to figure out if i want to spend the $400 on the bracket and compressor or if i want to try to make the stock one work
Old Apr 18, 2010 | 05:45 PM
6.0mustang's Avatar
you'll need a bigg condensor... the r12 condensors are less efficient because r12 has a higher boiling point, r134 has a lower boiling point there for you will need to cool the freon more to keep it liquified in the condensor. other than that... a/c compressor is apple to apples... but i'm pretty sure they are not variable compressors its a clutch cycling system. i dont think gm uses wobble plate compressors on anything (maybe caddilac)... but if i'm wrong still wont matter.
Old Apr 20, 2010 | 08:34 AM
G-Body's Avatar
Had to dig the pics out
Attached Thumbnails can i use the variable compression A/c compressor?-accut1.jpg   can i use the variable compression A/c compressor?-accut3.jpg   can i use the variable compression A/c compressor?-accut6.jpg   can i use the variable compression A/c compressor?-accut7.jpg   can i use the variable compression A/c compressor?-accut8.jpg
