E36 M3 - LS3 New headers finished..
Old Apr 20, 2010 | 06:53 AM
yamoda's Avatar
Default E36 M3 - LS3 New headers finished..
Your thoughts or comments would be appreciated.
Headers are custom built to fit the E36 M3 and are 1 7/8" primaries.
The rest of the system is twin 3" (Couldnt fit any bigger) through an X-pipe and a single large rear box custom made to fit and look fairly stock.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Apr 20, 2010 | 07:34 AM
rao's Avatar
rao
Looks good. If they allow you to fit the engine in the car then they are great I think 1 5/8" is a little on the small side, but it is tight in there.
That bell housing looks like it is upside down.
Old Apr 20, 2010 | 08:14 AM
Whitedevil666's Avatar
Those do look great. Primaries are smallish, but what can you do?
Is that an ax15 trans??
Old Apr 20, 2010 | 08:26 AM
yamoda's Avatar
Edited, The primary size is 1 7/8 not 1 5/8!!
AX15 or Toyota R154, the same trans (The totota has more suitable ratios) Might not be up to holding the power long term but I have 3 on the shelf and replacements can be had here for about £200 - £300 each.
Old Apr 20, 2010 | 08:42 AM
rao's Avatar
rao
Ah, that makes more sense
Got it on the trans as well, I guess everything is on the wrong side there
Old Apr 20, 2010 | 09:05 AM
Jimbo1367's Avatar
Headers look damn good IMO
Old Apr 20, 2010 | 10:36 AM
dpd069's Avatar
Very nice - did you fab them yourself?
A couple of things you might want to consider -
-Did you leak check them? I've made a seal for the head ports out of a flat board and a piece of rubber sheet from the hardware store and clamped it to the header with C clamps, then put an bicycle or motorcycle innertube on the collector end so I could pressurize it through the Schraeder valve and check with soapy water.
-I can't tell if the coating is paint or ceramic, but you might want to have them coated inside and out for thermal control if you haven't done so already
-Do you have your oxygen sensor bungs welded on?
Old Apr 20, 2010 | 11:16 AM
iflytii's Avatar
Those look good!
Old Apr 25, 2010 | 07:07 PM
Mateo M3's Avatar
nice work. looks good
Old May 3, 2010 | 10:23 AM
Pzary3233's Avatar
Very nice! I am interested to see how the fit in the car!
Can you spread some light on the R154? I've got a few sitting around....
Old May 5, 2010 | 09:04 PM
hefftone's Avatar
From: Dallas, Ga (2.7 miles from Southeastern Dragway)
Dude....those are sweet. Very clean and simple looking. I like the approach, especially how you positioned the collectors.... I'd like to have a set of those.
Old Dec 29, 2012 | 12:07 PM
yamoda's Avatar
it drives!!
