Drive by wire driving me crazy
Old May 6, 2010 | 03:00 PM
  #41
68 impala's Avatar
Sorry buddy, I tapped out. Same problem.
Old May 6, 2010 | 03:01 PM
  #42
CalEditor's Avatar
Originally Posted by 68 impala
Ok thanks for all the advice guy, but the fuel injection has been scraped. Went to livernoir motorsports and ordered intake/msd box/tci trans controller, today. Thank you all.
Sorry to hear that.
If you had issues with a DBW I can only imagine the issues you might have with a carb
Old May 6, 2010 | 03:44 PM
  #43
FrankZ's Avatar
just bought a better scanner than the POS Hador friegt one i was using. got the codes toclear and the throttle stated to work but I still get a p1518 and lose the throttle once I shut the engine down.
ARRRRRRGGGGGH!!!!!!!!
[/Charlie Brown voice]
Old May 24, 2010 | 11:00 PM
  #44
nmcgrawj's Avatar
Why not just switch to a cable TB?
(lsx noob here so go easy on me if thats not an option before resorting to carb)
Old May 24, 2010 | 11:04 PM
  #45
FrankZ's Avatar
Switched 2 wires in my harness and everying worked perfectly. TAC needs to be powered up before the PCM or the PCM reports a No Comm. with TAC.
Old Aug 21, 2010 | 03:13 PM
  #46
68 impala's Avatar
After months of chasing my tail and thousands of dollars spent, I have found that my 6.0. from a donor vehicle (2007 2wd chevy silverado classic crew cab 1500hd with 6.0 lq4/317 heads/4L80 trans), has a 58 tooth reluctor wheel. Finally after snatching the wiring harness and f.i. system (modified and flashed by SPEARTECH spring 2009) off after it was all installed but not functioning properly and then converting over to carb/intake, and still having electronic issues, the problem was narrowed down to timing. I spoke with edelbrock and MSD techs and they told me that the information that I believe to be true was incorrect (24x wheel) and they told me how to look and see.
Old Aug 21, 2010 | 03:28 PM
  #47
68 impala's Avatar
https://ls1tech.com/forums/conversio...l#post13762402
My post on this thread tell how this problem all came to an end.
Old Aug 25, 2010 | 11:38 PM
  #48
Eric Fischer's Avatar
Wow what a nitemare. It's too bad the PCM didn't set a relevant error code, it sure would have made your life easier.
Old Sep 5, 2010 | 01:08 PM
  #49
nostixs's Avatar
i also am having the same issue with my motor in an s10 starts up motor will die out after about 10 or 15 seconds of running. Also have a nonresponsive peddle with a 1518 code. Which 2 wires did u switch . Any help would greatly be appreciated.
Old Sep 6, 2010 | 09:59 AM
  #50
FrankZ's Avatar
I had the TCM power comming off the ASD relay in my PDC. not sure How I mamnaged to wire it there?
I moved it to another circuit that is hot in Start/Run.
Old Sep 6, 2010 | 10:35 AM
  #51
Disturbed 71's Avatar
I worked at a gm dealer for 9 years and never seen any issues with the fly by wire. I have the LQ9 in my Silverado SS. First thing I would get a better code reader with the ability to view data. Check and see what the pcm is seeing for the tps. Also with a better code reader it may give you thee code your engine light is trying to communicate to you. good luck
Old Sep 6, 2010 | 11:12 AM
  #52
FrankZ's Avatar
That's good to know, but a stock application is a far cry from stuffing a DBW motor and reworked harness into a different vehicle.
I'm vrry happy to hear that the system is reliable and hope that I'll never have to install my spare TAC module or hit the parts house to buy a replacement motor for the TB...but I'm realistic about it as well. Plan for the worst and hope for the best.
Old Sep 6, 2010 | 01:07 PM
  #53
You are 100% correct. If it wasnt ment to be there there is always room for challanges. My friend replaced the motor on his Subaru and had a simelar issues with crank cam signal due to number of teeth. The peeople at the dealer swore up and down that the teeth were the same on both engines. The current project I'm working on is a 71 Camaro LQ4 6.0L conversion. I have also been dreading the wiring but have seen several threads in here that can help you out in a major way.
Old May 3, 2020 | 02:12 AM
  #54
Loren Scott's Avatar
what 2 wire did you switch mine worked fine sent out the pcm and hooked everything back up powered it on it cycle but then heard a click and no pedal
Old May 3, 2020 | 10:12 AM
  #55
FrankZ hasn't been here in over 6 years.
Old May 4, 2020 | 07:13 PM
  #56
KW Baraka's Avatar
First Post + Bringing Up A 10 Year-Old Thread = Fake-Assed Troll
