SBC Crate Motor Smoking *PROBLEM SOLVED* Update Pg.2
I pulled the carb and see NO residue or oiling in the runners that I can see.
I pulled the valve covers and don't see anything abnormal but to be hones, with the springs there, I can't really see **** and I don't have the tools to remove the springs.
I guess I will just have to pull the heads.
I doubt the intake is leaking. I removed it a few months ago and put new gaskets in it carefully.
I have officially put summit on my list and will never order a single thing from them ever again.
I used to spend thousands of dollars with them repeatedly. Not anymore.
**** them. **** them hard.
How are they to know what you have done in that time frame?
A representative from Summit would have just as much luck knowing what transpired from "carnac the great" in that time frame.
I would tell you the same thing..
Oh well, not summit's fault they sell junk motors I guess.
My $20K HEMI was absolute junk.. And that was B4 it was even installed.
Ended up w/ a crank, rods, and bare heads...
Be thankful it's a cheapo SBC...
Problems like this with GM crate stuff has happened to me 2 times in the last 5 years. They will bend over backwards for you. They only will P and Moan about the cam if the cam is at fault, and they will bill you time and materials for it.
If your local one doesn't, feel free to come 1,000 miles north. There are 2 within 20 minutes of my house that will bend over backwards for you.
We took the car to a local GM dealership a week and a half ago. They called last Thursday and said they met with their Area Manager and they agreed to cover it under warranty. They said they would begin the teardown that day.
I JUST got a call from the service manager saying that the car was fixed, done and ready to be picked up.
I called my father and he is happy as all get out that his baby is no longer smoking.
I am extremely happy with the dealership for covering this issue and getting her all fixed up.
The problem was...............
The valve stem seals were crushed and leaking
