LS1 in 95 Formula help
Old May 4, 2010 | 02:34 PM
formula1785's Avatar
Default LS1 in 95 Formula help
Getting things i need for the swap..
need some help though..
what will i need.
going to use stock k-member.
Old May 4, 2010 | 02:49 PM
LilJayV10's Avatar
Are you using the LT or LS crossmember? I think there are several threads about this swap going on right now.
Old May 4, 2010 | 03:51 PM
well just found out cant use the lt one..
will an aftermarket k member be used with a lt rack and pinion??
Old May 4, 2010 | 08:55 PM
LilJayV10's Avatar
I believe only the motor mounts are different.
Old May 4, 2010 | 11:19 PM
AnniversaryZ28's Avatar
I just bought a LS rack and a LS k-member. Made everything very easy.
Swapping the rack is super easy, and cheaper than going aftermarket.
Old May 5, 2010 | 12:58 AM
If I buy the aftermarket k member from ubi will mu LT brakes and all other parts fit?
Old May 5, 2010 | 01:03 AM
Got some pics of some LS swaps? Trying to get as much info as I need before I buy and start my build?
Old May 5, 2010 | 03:18 PM
if i had the harness rewired would it be able to work with the stock gauges i have now??
Old May 5, 2010 | 03:56 PM
blk96406's Avatar
https://ls1tech.com/forums/conversio...questions.html
This is just one thread of MANY, take some time and dig around- you will find everything here to do it...........
Old May 5, 2010 | 06:01 PM
VIPRETR2's Avatar
I searched my *** off to find this link for you so I hope it helps. Goofy underscores in screennames _
https://ls1tech.com/forums/conversio...o-lt1-car.html
the_merv has several other threads in this forum that will help as well. Good luck,
Larry
Old May 6, 2010 | 08:18 PM
flame's Avatar
Check out the link in my sig for info on my swap
