94 white FD LS1, Turbonetics T76, Cobra IRS, C6 manifolds.
Old 05-10-2010, 11:44 AM
dan81386's Avatar
Old 05-13-2010, 11:04 PM
dan81386's Avatar
i picked up some stainless today for the hot side. i should have pics of it this weekend
Old 05-14-2010, 08:31 AM
SS-TEN's Avatar
Sweet man. That sure is some good quality fab work!
Old 05-14-2010, 09:19 AM
oldschoolmuscle's Avatar
looks good..
Old 05-14-2010, 11:33 AM
beatmeofficer's Avatar
great job with the build so far man
Old 05-17-2010, 10:04 PM
dan81386's Avatar
merge pipe is almost done. should have pics when i get back from vacation
Old 05-17-2010, 10:52 PM
simple's Avatar
VERY NICE!
I'm poor so i'm doing a FC, TC76 turbo ls1 using C6 manifolds out of my garage.
Turbo location should be very similar to yours accept i'm hoping to give the down pipe a straight shot right off the turbo (no bends until the firewall) between the strut tower and valve cover. Atleast thats the layout i have in my head so far.
Looks like there is a little more room in an FC then in an FD.
Did you use these flanges for the manifolds?.....
http://www.stainlessworks.net/cart/i...95_131_418_430
(direct bolt onto the C6 manifolds?)
Whats the dimensions on your intercooler?
Old 05-18-2010, 09:37 AM
dan81386's Avatar
Originally Posted by simple
VERY NICE!
the fc does have alot more room in the engine bay.this was the only way i could make it still look good while showcasing the turbo and have the turbo inlet not run right into the radiator. yes i got my flanges from stainless works. they didnt have them on the web page before i had to call and give them the specs and they had some cut
Old 05-18-2010, 09:38 AM
dan81386's Avatar
VERY NICE!
btw that link is not the correct flange. you must call them and tell them you want the c6 flange. i can get a part number for you if you would like
Old 05-18-2010, 11:22 AM
Convette's Avatar
Very nice build man. I love white cars on black.
Old 07-09-2010, 08:22 PM
Raz
Raz's Avatar
Any updates? Love to see some
Old 07-12-2010, 12:37 AM
  #32
Speedy911's Avatar
Sweet looking car, updates!!!!
Old 07-12-2010, 09:33 AM
  #33
dan81386's Avatar
i did some work on it this weekend but no pics yet. i have been working on the rad hoses and down pipe
Old 07-12-2010, 11:13 AM
  #34
navi243's Avatar
what was involved in getting the Cobra IRS to mount up to the car?
Old 07-13-2010, 08:51 AM
  #35
dan81386's Avatar
samberg rod and custom makes a kit. basically uses cobra diff and inner cv's w/ drave shaft shop conversion axles and modded rx7 rear sub-frame
Old 07-13-2010, 08:54 AM
  #36
dan81386's Avatar
i used another rx7club memebers subframe kit. it is no longer in production tho
Old 07-13-2010, 04:37 PM
  #37
bonecrrusher's Avatar
Nice PT front plate on the wall...
That rear susp looks bitchin!
Old 07-13-2010, 04:46 PM
  #38
ROTAROLLA's Avatar
Do the stock C6 manifolds not hit the Frame Rails?
Do you have a picture of the hot side off the car?
Thanks
Old 07-14-2010, 01:02 PM
  #39
dan81386's Avatar
Thanks
the stock c6 ls3 maifolds fit great. but i was running into issues when i flipped them forward for the turbo set up. the issue is that it is very close to the steering shaft. they do fit but it is tight. if you are running them the "normal" way (out the rear) then they clear with tons of room to spare. i will have pics of the hot side up hopefully this weekend
Old 08-12-2010, 05:25 PM
  #40
dan81386's Avatar
from the pics it looks like the pipe fitment is very close to touching other parts of the car. this is not the case there is actually at least 1.5" + of clearence in the tightest areas. it is very hard to capture this with a camera though.
Quick Reply: 94 white FD LS1, Turbonetics T76, Cobra IRS, C6 manifolds.
