6.2L VVT with 4L70E computer match up problem
Old May 11, 2010 | 01:30 PM
68Problemchild's Avatar
Default 6.2L VVT with 4L70E computer match up problem
My programmer is indicating there may be an issue with the E38 PCM on a 6.2L VVT 2007 Escalade talking to the T42 transmission computer in my 4L70E.
He says I may need a new E67 PCM to make it work.
Has this been done? I thought plenty of Trailblazers had 4 speeds?
Thanks!!!!
Old May 11, 2010 | 01:49 PM
Jones'n's Avatar
There aren't any E38 controlled VVT engines from the factory that have a 4L70E on them.
So what he is saying is that programming the TCM with a 4L70E program from lets say a 2007 Trailblazer, then putting that on an E38 computer with a program for an Escalade or something is kind of an unknown combo. No real way of knowing if it works until you do it.
Old May 11, 2010 | 02:05 PM
Yikes. As a fall back, do I get a 6 speed tranny? Any cheaper way?
6L80E requires some tunnel smashing to fit as I understand....
Thanks.
Old May 11, 2010 | 02:50 PM
Jones'n's Avatar
1. A 6 speed Auto
2. An aftermarket trans controller for the 4 speed
3. A non electric transmission
4. Ditch the VVT
5. Try it and see what happens.
Anyone else with a thought?
Old May 13, 2010 | 01:31 AM
jsmechanical's Avatar
This is a common question at the moment it seems, I haven't seen a definative answer yet. jakeshoe has made some posts regarding mating VVT E38/T42 combos to the 4L80e trannies, he might be the person to ask whether it is possible to set them up with ISS 4L65/70's. jakesperformance.com
Old May 13, 2010 | 06:42 AM
3pedals's Avatar
my buddy is in the same boat -LY6vvt, to 4L70E. I know little of this so I am no help to him. what does he do if he eliminates VVT?
Old May 13, 2010 | 11:20 PM
If you eliminate the VVT it can be made to work. There are ECM/TCM Operating System calibrations available for the E38/T42/4L65/70e combo. An factory example of this is the 2007 Holden VZ Commodore which runs a L76/4L65e with ISS using the E38/T42. There are also export VE Commodores (Pontiac G8) that are exported to the middle east with this same combo. That is the OS I am using for my setup which is E38/T42/58x LS2 block/L92 heads/L76 manifold/4L60e retrofitted with an input speed sensor.
Having said this I still think it is worth pursuing the idea of using the VVT if it possible
Old Feb 24, 2011 | 04:47 PM
LCAC_Man's Avatar
I know this is an old post but I was wondering if this combo (E38, VVT, T42,4l70e) was found to work?
Old Feb 24, 2011 | 07:00 PM
Bo185's Avatar
The 2010 up trucks uses the E38 with the L20 4.8L VVT motors and 4l70 as well as the LH9 5.3L VVT / 4l70 used in the Colorado. I don't see why it couldn't be made to work based off that.
Old Feb 25, 2011 | 09:38 AM
LCAC_Man's Avatar
Thats good news...making a deal on an L92/4l70e package for my ragtop!
Old Feb 25, 2011 | 11:47 AM
cam's Avatar
cam
Yup 2010 and up 4.8L e38 with VVT and 4spd auto. Should work out well
Old Mar 4, 2011 | 03:40 PM
LCAC_Man's Avatar
Does that combo still utilize the T42 TCM's or is that integrated in the e38 now?
Old Mar 4, 2011 | 03:52 PM
Bo185's Avatar
They use T42 with the 4l70, the later ECM have no provisions to control the transmission.
Old Mar 4, 2011 | 04:56 PM
cam's Avatar
cam
**** I wasnt aware that there was an update to the e38. Thanks for catching that fellas. It should still work though yes?
Old Jul 13, 2011 | 05:57 PM
This had some glitches but yes with the truck combo its finally working.
Old Jul 13, 2011 | 07:24 PM
ponjohn's Avatar
Can the newer PCM work with a 4l80e?
Does anyone have the p/n for the updated E38?
Old Jul 14, 2011 | 02:02 PM
ponjohn's Avatar
I think this is it... 12625455
Old Jul 17, 2011 | 09:33 AM
This is what I used that worked. We laid the tune over the original L92 2007 Escalade computers. E38 and T42.
2007 Silverado Vortec VVT new body style truck OS, 2 Wheel drive with 4L70E. Engine displacement is different but that is about all.
