Reverse light switch location - T56
Can anyone tell me real quick where the reverse light switch is located on a T56? It's out of an '02 Camaro if it matters. I can't find my manual at the moment and a quick google search didn't come up with anything. Thanks.
It is plugged into the side of the T56, then goes through the harness.
It is in Connector C220 pins G & H
C220 - natural color 10 pin connector.
A (optional) TAN - Oil pressure output
B (optional) GRY - clutch pedal switch
C (remove) - Power supply to TCC stop lamp switch
D (remove) - TCC stop lamp switch
E (not used) BLK/WHT - (ground in?)
F (not used)
G BRN - Connect to original backup light harness - Backup light switch 12v"+" power input
H LT GRN - Connect to original backup light harness - Backup light switch out to light
J (not needed)
K DK GRN/WHT - Connect to your speedometer’s signal input - VSS signal to speedometer (4000ppm)
F (not used)
J (not needed)
F (not used)
J (not needed)
F (not used)
J (not needed)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
