Pre-planning my LQ4/L92 build to ZF transmission (92 Vette) ZF familiar please look
I'm looking to do an LQ4 block and have searched a good bit on LS-ZF adapters or people that have mated the two. ZFdoc did it, but it involved opening the transmission, something I'm not interested in doing if it isn't necessary. I then located this company that sells a bellhousing adapter. I read that it appears fabbing a mount for the slave or an internal hydraulic throwout bearing would be necessary. I have no problem fabbing a mount if that's all that's necessary. Is there some other complexities that aren't obvious with this?
Does this appear to be that straightforward based on the pic?
http://www.quicktimeinc.com/products.html
The adapter is RM 6039...just scroll down a bit...they are in numerical order.
