c5 vette filter regulator question
Old May 23, 2010 | 11:49 AM
gonzo 6.2's Avatar
Default c5 vette filter regulator question
Any one know what the pressure might be if the return line was restricted or blocked?
Old May 23, 2010 | 05:32 PM
Jimbo1367's Avatar
higher than 58-61 is a guess
Old May 23, 2010 | 05:58 PM
ls1nova71's Avatar
It would depend on HOW blocked it is. If it's totally blocked, it would be whatever your pump will push.
Old May 23, 2010 | 06:27 PM
crainholio's Avatar
Same question in different context:
If you had a piece of string, and you cut it, how long would it be?
Old May 23, 2010 | 10:58 PM
gonzo 6.2's Avatar
fuel reg. is on frame rail right behind right front tire,return line is connected to OE return line,which runs the length of the frame.I can blow thru it ,it takes a lot of blow and its low volume.Im getting 68LBs at idle,these vette regs should be 58lbs?
external walbro.
guess an easy test is to run return line from reg to gas can take reading.
THANKS to all replys
