LS1 into 95Z
Old May 23, 2010 | 04:30 PM
95sscamaro's Avatar
Default LS1 into 95Z
Im thinking of putting an ls1 in place of the LT1. what would i need to do this?
Old May 23, 2010 | 04:31 PM
MonmouthCtyLS7's Avatar
Good idea ...Several write ups on this here.....just do a search "the merv" has some good info. Thats his username. Right off the top of my head u need K-member, rack and pinion, ls1 engine mounts, pcm, wiring harness.
Old May 23, 2010 | 05:21 PM
Matts94Z28's Avatar
...an ls1...
Old May 23, 2010 | 06:08 PM
Johnny-LT1-runner's Avatar
Rockstar
Originally Posted by Matts94Z28
...an ls1...
This. And all the matching goodies.
Old May 23, 2010 | 06:10 PM
...an ls1...
get outta here?..................
Old May 23, 2010 | 07:08 PM
fatbody99's Avatar
Was planing on doing the umi k member with the change. I'm going to use the lt1 to put in a s10 to transport the camaro
Old May 23, 2010 | 07:17 PM
95sscamaro's Avatar
I have a m6 will the trans/ clutch bolt Right up ?
Old May 23, 2010 | 08:00 PM
shbox's Avatar
Nope, you will need that, too.
Old May 23, 2010 | 08:27 PM
gregrob's Avatar
You can swap the input shaft and use your trans... you will need an ls clutch setup though.
Although I feel the entire swap is retarded. Build them both and they will both produce great power. After all the ls cars I've raped with my baby cam only setup I would never consider switching. All I want is their coil packs
Old May 23, 2010 | 08:43 PM
SS MPSTR's Avatar
24x EFI connection is your friend.
Old May 23, 2010 | 08:54 PM
95sscamaro's Avatar
Who said it was going to be a stock ls1 h/c/I should do.
Old May 23, 2010 | 09:03 PM
gregrob's Avatar
Yep..
